Removing finish between frets http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=45513 |
Author: | Chris Ensor [ Thu Apr 09, 2015 6:22 pm ] |
Post subject: | Removing finish between frets |
I did my best to mask my FB, but I still got bleed under the tape. Now I need some suggestions for removing the finish right up against the frets. If it helps, the finish is west systems epoxy, 2lb shellac, and em6000. Here's a pic: Attachment: IMG_1322e.jpg Thanks for the help. |
Author: | johnparchem [ Thu Apr 09, 2015 6:27 pm ] |
Post subject: | Re: Removing finish between frets |
I use a straight edge razor blade as a scraper |
Author: | Kevin Mason [ Thu Apr 09, 2015 6:31 pm ] |
Razor blade as a scrapper. I add masking tape with only 1/8 to 1/4 inch of the blade exposed. |
Author: | DannyV [ Thu Apr 09, 2015 6:32 pm ] |
What John said. That's a lot of finish. I find taping up to either side of the fret and rubbing the tape down with a small stick of wood helps. Then tape over the fret and do the same. |
Author: | Tom West [ Thu Apr 09, 2015 7:22 pm ] |
johnparchem wrote: I use a straight edge razor blade as a scraper Yes sir.............! Tom |
Author: | Hesh [ Thu Apr 09, 2015 7:23 pm ] |
Single edged razor blade also used as a scraper using the entire blade. You can finish up with small wood blocks that are radiused to match the board with 220 on them. This is a Frank Ford method, the blocks, he's not keen on scrapers for this because of chattering. |
Author: | Josh H [ Thu Apr 09, 2015 9:13 pm ] |
In addition to what everyone has said about the razor blades, I find that a sharp chisel can often work well as a scraper. I like using my ¼" or even ⅛" chisels when I get up around the higher frets. I don't think anyone has mentioned this, but I always make sure to break the finish at the edge of the fretboard before cleaning around fret ends. If your finish is wrapped around the edge of the fretboard onto the face, and you try to scrape it off the face you run the risk of pulling up finish along the edge of the board. Breaking the finish is easily done when the fret ends are beveled. Or if they are beveled before the finish is applied I just run my file lightly over the edge to break the finish. |
Author: | Ben-Had [ Thu Apr 09, 2015 9:17 pm ] |
I use a tool they use in the Martin Factory. I was shown it's use by Dale Bartholomew who was a supervisor in the Martin finishing area for years. It has more stiffness than a razor and I was amazed how well it works. It can be seen here (go to the 37:30 mark of the video) scraping bindings after the body has been pore filled: https://www.youtube.com/watch?v=lxR_cvJoci8 |
Author: | johnparchem [ Thu Apr 09, 2015 9:32 pm ] |
Ben-Had wrote: I use a tool they use in the Martin Factory. I was shown it's use by Dale Bartholomew who was a supervisor in the Martin finishing area for years. It has more stiffness than a razor and I was amazed how well it works. It can be seen here (go to the 37:30 mark of the video) scraping bindings after the body has been pore filled: Is it a notched scraper? I made and used one an electric guitar after spraying a burst. It sure beat trying to tape the bindings. |
Author: | Ben-Had [ Fri Apr 10, 2015 9:31 am ] |
johnparchem wrote: Ben-Had wrote: I use a tool they use in the Martin Factory. I was shown it's use by Dale Bartholomew who was a supervisor in the Martin finishing area for years. It has more stiffness than a razor and I was amazed how well it works. It can be seen here (go to the 37:30 mark of the video) scraping bindings after the body has been pore filled: Is it a notched scraper? I made and used one an electric guitar after spraying a burst. It sure beat trying to tape the bindings. No, it's basically like using a chisel backwards as a scraper but the metal is a little thinner. Got this pic off Frank Ford's site he uses one too. |
Author: | Chris Ensor [ Fri Apr 10, 2015 10:07 am ] |
Hesh wrote: Single edged razor blade also used as a scraper using the entire blade. You can finish up with small wood blocks that are radiused to match the board with 220 on them. This is a Frank Ford method, the blocks, he's not keen on scrapers for this because of chattering. Can you post a link to the radiused blocks that Frank Ford makes? |
Author: | WudWerkr [ Fri Apr 10, 2015 12:20 pm ] |
johnparchem wrote: I use a straight edge razor blade as a scraper yep |
Author: | Hesh [ Fri Apr 10, 2015 2:04 pm ] |
Chris Ensor wrote: Hesh wrote: Single edged razor blade also used as a scraper using the entire blade. You can finish up with small wood blocks that are radiused to match the board with 220 on them. This is a Frank Ford method, the blocks, he's not keen on scrapers for this because of chattering. Can you post a link to the radiused blocks that Frank Ford makes? Hey Chris: I just did a couple of searches of Frank's posts and can't find it.... I also went to FRETS and could not find it there either. I am sure that he posted some pics and likely last fall IIRC. Maybe someone can help me find it, please? Thanks. Anyway they are simply small wooden blocks that are smaller than the distance between frets so that with sand paper (wonder if this will offend the plane guys..... ![]() On constant radius boards this would be a pretty easy shop-made tool and could be done on compound radius too with perhaps 1/2" thick super dense rubber blocks that can still conform to the radius. |
Author: | The Claw [ Sat Apr 11, 2015 10:27 pm ] |
Wait till you're ready to do the fretwork. All that will come off if you bevel the edge of the fingerboard/frets with a bastard file and/or block with sandpaper Less risk of chip-out than scraping! Whatever is left over can be scraped with a good razor blade. |
Author: | meddlingfool [ Sun Apr 12, 2015 2:21 am ] |
A good example of why I prefer to fret after finishing. Both ways work of course, but for me fretting is the 3rd to last step. |
Author: | uvh sam [ Sun Apr 12, 2015 10:05 am ] |
I break the finish with 400 grit paper and then scrape clean. No need to over complicate it. |
Author: | kencierp [ Sun Apr 12, 2015 10:24 am ] |
Quote: I break the finish with 400 grit paper and then scrape clean. No need to over complicate it. Ditto |
