It is currently Fri Jul 11, 2025 10:39 pm
PostPosted: Thu Apr 09, 2015 6:22 pm
Last Name: Ensor
City: Springfield
State: Missouri
I did my best to mask my FB, but I still got bleed under the tape. Now I need some suggestions for removing the finish right up against the frets. If it helps, the finish is west systems epoxy, 2lb shellac, and em6000. Here's a pic:
Thanks for the help.
http://elevatelutherie.com
http://ensorguitars.com
PostPosted: Thu Apr 09, 2015 6:27 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
I use a straight edge razor blade as a scraper
PostPosted: Thu Apr 09, 2015 6:31 pm
First name: Kevin
Last Name: Mason
City: Wheeling
State: IL
Zip/Postal Code: 60090
Razor blade as a scrapper. I add masking tape with only 1/8 to 1/4 inch of the blade exposed.
Kevin Mason
Mason Guitars and Ukuleles on Facebook
http://masonguitars.net
PostPosted: Thu Apr 09, 2015 6:32 pm
First name: Danny
Last Name: Vincent
What John said. That's a lot of finish. I find taping up to either side of the fret and rubbing the tape down with a small stick of wood helps. Then tape over the fret and do the same.
PostPosted: Thu Apr 09, 2015 7:22 pm
First name: Tom
Last Name: West
State: Nova Scotia
Yes sir.............!
Tom
PostPosted: Thu Apr 09, 2015 7:23 pm
Single edged razor blade also used as a scraper using the entire blade.
You can finish up with small wood blocks that are radiused to match the board with 220 on them. This is a Frank Ford method, the blocks, he's not keen on scrapers for this because of chattering.
These users thanked the author Hesh for the post: DannyV (Sun Apr 12, 2015 10:30 am)
PostPosted: Thu Apr 09, 2015 9:13 pm
State: ON
In addition to what everyone has said about the razor blades, I find that a sharp chisel can often work well as a scraper. I like using my ¼" or even ⅛" chisels when I get up around the higher frets.
I don't think anyone has mentioned this, but I always make sure to break the finish at the edge of the fretboard before cleaning around fret ends. If your finish is wrapped around the edge of the fretboard onto the face, and you try to scrape it off the face you run the risk of pulling up finish along the edge of the board. Breaking the finish is easily done when the fret ends are beveled. Or if they are beveled before the finish is applied I just run my file lightly over the edge to break the finish.
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
These users thanked the author Josh H for the post: Hesh (Fri Apr 10, 2015 1:53 pm)
PostPosted: Thu Apr 09, 2015 9:17 pm
First name: Tim
Last Name: Benware
City: Creedmoor
Zip/Postal Code: 27522
I use a tool they use in the Martin Factory. I was shown it's use by Dale Bartholomew who was a supervisor in the Martin finishing area for years. It has more stiffness than a razor and I was amazed how well it works. It can be seen here (go to the 37:30 mark of the video) scraping bindings after the body has been pore filled:
https://www.youtube.com/watch?v=lxR_cvJoci8
"I've been had again"
Tim Benware
Creedmoor, NC
PostPosted: Thu Apr 09, 2015 9:32 pm
Last Name: Parchem
City: Seattle
State: Wa
Is it a notched scraper? I made and used one an electric guitar after spraying a burst. It sure beat trying to tape the bindings.
PostPosted: Fri Apr 10, 2015 9:31 am
First name: Tim
Last Name: Benware
City: Creedmoor
No, it's basically like using a chisel backwards as a scraper but the metal is a little thinner. Got this pic off Frank Ford's site he uses one too.
Tim Benware
Creedmoor, NC
PostPosted: Fri Apr 10, 2015 10:07 am
Last Name: Ensor
City: Springfield
State: Missouri
Can you post a link to the radiused blocks that Frank Ford makes?
PostPosted: Fri Apr 10, 2015 12:20 pm
First name: Big
Last Name: Jim
yep
PostPosted: Fri Apr 10, 2015 2:04 pm
Hey Chris: I just did a couple of searches of Frank's posts and can't find it.... I also went to FRETS and could not find it there either. I am sure that he posted some pics and likely last fall IIRC.
Maybe someone can help me find it, please? Thanks.
Anyway they are simply small wooden blocks that are smaller than the distance between frets so that with sand paper (wonder if this will offend the plane guys..... :D ) attached you sand between the frets.
On constant radius boards this would be a pretty easy shop-made tool and could be done on compound radius too with perhaps 1/2" thick super dense rubber blocks that can still conform to the radius.
PostPosted: Sat Apr 11, 2015 10:27 pm
Zip/Postal Code: 60622
Wait till you're ready to do the fretwork. All that will come off if you bevel the edge of the fingerboard/frets with a bastard file and/or block with sandpaper Less risk of chip-out than scraping! Whatever is left over can be scraped with a good razor blade.
PostPosted: Sun Apr 12, 2015 2:21 am
A good example of why I prefer to fret after finishing. Both ways work of course, but for me fretting is the 3rd to last step.
These users thanked the author meddlingfool for the post: Hesh (Sun Apr 12, 2015 9:07 am)
PostPosted: Sun Apr 12, 2015 10:05 am
First name: sam
Last Name: guidry
State: michigan
Country: us
I break the finish with 400 grit paper and then scrape clean. No need to over complicate it.
These users thanked the author uvh sam for the post: kencierp (Sun Apr 12, 2015 10:23 am)
PostPosted: Sun Apr 12, 2015 10:24 am
Ditto
Ken Cierp
Users browsing this forum: DennisK, eflottman and 26 guests
