It is currently Fri Aug 22, 2025 6:57 am
 Post subject: Torres FE17 guitar plans
PostPosted: Mon Dec 31, 2018 12:01 am
Still trying to educate myself on the future projects I could foresee for the upcoming years: Is there somewhere one could find a set for the FE17 Antonio de Torres guitar? Thanks!
PostPosted: Mon Dec 31, 2018 7:28 am
First name: Ernest
Last Name: Kleinman
City: Guthrie
Zip/Postal Code: 73044
Hi flying red . You might have better luck posting your query on the Delcamp forum , (gotta register) lots of classical guitar makers and players
These users thanked the author Ernie Kleinman for the post: FlyingFred (Mon Dec 31, 2018 10:04 am)
PostPosted: Mon Dec 31, 2018 10:03 am
Thanks! Will follow your advice.
PostPosted: Mon Dec 31, 2018 10:04 am
These may help
http://www.antoniodetorres.es/index.php?option=com_guitarbook&view=detail&id=26&Itemid=2
http://www.jitamen.com/wp-content/uploads/2012/09/Plano_torres_1864-FE17-1.pdf
Good luck with your hunt
PostPosted: Mon Dec 31, 2018 1:36 pm
I have a drawing of the FE17 soundboard only, in PDF. If you'd like a copy, drop me a PM.
These users thanked the author Carey for the post: FlyingFred (Tue Jan 01, 2019 5:18 pm)
PostPosted: Thu Jan 03, 2019 8:51 pm
First name: Wendy
Last Name: W
State: Arizona
This was sent to me years ago by Douglas Ingram when I wanted to build an FE17, along with the soundboard diagram that Colin posted. I have built 3 of these and they are the best sounding guitars I have built. Hope this helps, Wendy
And some measurements made by Jason Wolverton from the original:
The nut width is 48 mm.
The fingerboard is 58 mm at the 12 fret.
The bridge is 164 mm long by 28 mm wide.
The saddle and tie block are 77 mm long.
The bridge wings are 44 mm long and rather thick (approx 5 mm)
The string spacing on the tie block is about 55.5 mm
There is a fair amount of doming in the lower bout, approximately 5 mm.
The back purfling goes in about 8 mm including the binding (which is thin at about 1 mm.)
A couple other things. Torres backs are typically 2.5mm or more, depending upon the species of wood, the particular piece, and its inherent qualities.
The sides should be between 1 and 2mm. The thin sides contribute to the "open"quality. Its difficult to make absolute statements about the thickness of the top as so much depends upon the particular piece of wood, but 2.5mm center and thinning to 1.5mm at the perimeter works as a guideline. Experience will inform future builds.
With the 5mm doming that Jason measured, I worked out that there is NO forward angle to the neck.
I have to provide this bit of information. I have built a number of guitars before exploring FE17, and I thought that they sounded pretty good. And they did, until I built this guitar. No they all sound like crap. At least they do relative to this guitar
Before I write anymore, I do have to point out that I am indebted to the generous offering of help and experience that I received from Gerhard Oldiges, in making the tornavoz something more that an anachronism. Read my Delcamp forum build thread and you will learn all that I know, and with pictures!
The overall sound is very rich, like good dark chocolate compared to milk chocolate. The bass is very profound, the mids clear, and the trebles sound like so clear and pure compared to anything else that I have built. Everyone who has heard it, and so far that comprises only non-guitar people, the ALL notice this. Last week I showed it to a friend who confessed that he can't hear the difference of one guitar to another (they all sound like guitars...), well he could hear it. He said that the other guitars struggled to put the sound out all over the room, while the FE17 shot it out like a laser, in addition to just sounder richer.
The volume is excellent, as is evenness across the strings. Sound is very quick, you don't need to work to get the guitar to respond, and the sustain is also very good.
My wife, who is a cello player, has noted the qualities of this guitar, saying that if I specialize in only one guitar, it should be this one.
Not bad for a guitar made with no new money, $32 if I account for the materials actual value, and using wood that no serious luthier could make a salable guitar from: White Pine and Green Ash. Makes me wonder what the results will be if I build with "good" materials?
Good luck!
Douglas Ingram
These users thanked the author WendyW for the post: FlyingFred (Sun Jan 06, 2019 12:23 am)
