"tinted" maple acoustic?
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=51668
Author:  sdsollod [ Thu Feb 28, 2019 6:17 pm ]
Post subject:  "tinted" maple acoustic?
Have you ever "tinted" a maple acoustic with any color? This is typically a treatment that an electric guitar might get. I realize that it is unconventional, but I don't mind being unconventional sometimes. I'm trying to decide whether to simply go with natural on my current maple OM build or perhaps add a little black transtint to the finish and give it a slight gray color. Maybe even bring out the figure with some transtint directly, then sand back. Or... I may bag the whole idea and just go natural...
Author:  Bri [ Thu Feb 28, 2019 9:20 pm ]
Post subject:  Re: "tinted" maple acoustic?
For figured maple I like to use a dark amber tint, light sand back, then clear. Something to pop the figure.
B
Author:  Terence Kennedy [ Thu Feb 28, 2019 11:42 pm ]
I've done a couple of Bird's Eye Maple with a darker amber tint. They looked pretty cool. They were double side with a rosewood inner side.
Author:  sdsollod [ Fri Mar 01, 2019 8:39 am ]
That is super nice...
Author:  Luthier1975 [ Fri Mar 01, 2019 1:55 pm ]
I'm in the exact same spot for an OM I am ready to finish made with quilted maple back and sides with a flame maple neck. Deciding what color, if any, right now is a tough decision. I started out thinking a full burst but I am about to wipe on a brown stain and then clear over, go for an old look. But I'm still not sure.
What other options are you considering with the black tint?
Author:  Colin North [ Fri Mar 01, 2019 2:01 pm ]
Following, got a sweet set of flamed cherry and thinking something like brown/red for that.
Or maybe purple?
Author:  sdsollod [ Fri Mar 01, 2019 2:21 pm ]
Purple Colin? That IS unconventional...
Blake - What brown stain would you be using?
My idea would be similar to what you might see on the top of a Les Paul. A black transtint solution would be applied so that the dye penetrates, then sand to bring out the figure, and then mix a little black transtint in my finish (EM6000) and spray on a transparent black color. That would be followed by clear coats. It would not be too dark and the figure would show through. I would put on a couple of clear coats on first in case I need to try it again... Like I said, perhaps it would be unconventional on an acoustic, but it might look striking...
Author:  TimAllen [ Fri Mar 01, 2019 5:03 pm ]
The black Transtint stain followed by lacquer toned with Transtint seems like it would work well, and it I agree that it would have a Les Paul sort of appearance.
Staining maple to darken the grain normally "brings out" the grain but reduces the apparent movement / 3-dimensional appearance of figured maple. In the violin making world I understand that they generally prefer to finish so the movement of the grain shows.
Popping the grain with a stain is superior if you want to maximize how figured the wood looks in a still photo. Otherwise, there's no right or wrong--it just depends on how you want that particular finish to look.
If you want to darken the wood without reducing the apparent three-dimensional look, you can either use a colored finish, or pre-treat with a wash coat of shellac followed by dilute water-based aniline dye.
Author:  Colin North [ Fri Mar 01, 2019 5:26 pm ]
Author:  sdsollod [ Fri Mar 01, 2019 7:08 pm ]
Tim, that’s a good point about reducing the 3-D effect of figure. Something to consider...
