It is currently Sun Sep 21, 2025 6:32 pm
 Post subject: Wet coat with Nitro
PostPosted: Tue Apr 16, 2019 3:50 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I'm using a nice gun prolly 1-2 mm tip, HVLP. I am trying to achieve a wetter application. Seems my stuff dries pretty quick. Thoughts? (Mohawk Nitro, Behlen formulation)
 Post subject: Re: Wet coat with Nitro
PostPosted: Tue Apr 16, 2019 4:14 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
do you use a wet film thickness gauge to know how thick you are spraying?
PostPosted: Tue Apr 16, 2019 4:23 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
No. I don't know what that is. But I can assure u I am blowing a lot of finish because it is too dry.
PostPosted: Tue Apr 16, 2019 4:55 pm
Last Name: Parchem
City: Seattle
State: Wa
you can get them for free at a lot of paint stores or have amazon deliver one for about $10 https://www.amazon.com/82-479-Film-Gauge-1-80-Scale/dp/B01BM7MU02. It allows you to measure the film you are laying down. I check it out on a test panel using the same spray pattern I spray with. It is is handy to know because with that information and the percentage of solids in the lacquer you can calculate your dry film thickness.
You are asking formulations I would be questioning my gun setup first.
PostPosted: Tue Apr 16, 2019 5:00 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
How quick? Is it dry spaying on the surface? Could be gun set up, could also be application technique..... Make sure your gun is set up properly first like I show here https://howardguitars.blogspot.com/2015/06/spray-gun-setup-technique-by-brian.html
Brian
PostPosted: Tue Apr 16, 2019 5:56 pm
Follow the gun setup on B. Howards link first. I use Mohawk Piano Lacquer but I build solid body only. I would use the Stringed Instrument lacquer for hollow body guitars. Either Mohawk or Behlen which is Mohawk anyway. They are designed to spray without thinning. Thinning gave me problems.
http://www.luthiersforum.com/forum/viewtopic.php?f=10123&t=51785
PostPosted: Tue Apr 16, 2019 8:06 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
What gun? Conversion or turbine? There is a big difference between a 1mm tip and a 2mm tip...what tip set is recommended for your gun when shooting lacquers?
- Beth Brower
PostPosted: Tue Apr 16, 2019 9:33 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I had a can of retarder. Seemed to solve the problem. the gun is an Italian thing... remember in morn. Love it though, not turbine, not conversion, true HVLP
PostPosted: Wed Apr 17, 2019 5:36 am
If what you mean by "true HVLP" is a pressure pot and two hose to the gun type, you might want to try running some thinner through the fluid hose to clean it out to allow more fluid flow. You might also check that the regulators are working properly. Generally dry films are from too much air in the air/finish mix or spraying too far away.
PostPosted: Wed Apr 17, 2019 6:09 am
First name: Willard
Last Name: Guthrie
City: Cumberland
I am happy you got things to work with your existing spray rig.
Your gun is likely a conversion gun, which just means the low volume, high pressure air from your compressor is converted to high volume, low pressure air in the gun, versus a turbine HVLP gun, where the HVLP air is generated external to the gun using a single or multi-stage turbine. While both types are essentially identical once the HVLP air is mixed with finish and applied, they have some unique issues (e.g., drying and cleaning the air for a conversion gun; cooling the hot, very dry flow for a turbine gun), so worth knowing which type.
I'm not certain 'true HVLP' is not a marketing term - compliance is more the concern with HVLP spray guns, as in compliance with 40 CFR Part 63 rules which apply to the spraying of VOC and HAP-containing finishes. The usual guideline cited for HVLP is a tip pressure of 10 PSI or less, but there are a number of ways to get there.
- Beth Brower
PostPosted: Wed Apr 17, 2019 6:11 am
Last Name: Howard
City: Magnolia
State: Delaware
Might be like swatting flies with dynamite... retarder is heavy and should only be used in modern nitro formulas when absolutely necessary. You have likely added a few weeks to your cure to buff time as it will take a while for that to gas out.
True HVLP? I have used many different designs of that over the years. From guns that look like siphon cup guns to Gravity fed. HVLP Deals mainly with the airflow through the gun, High volume of air at lower pressures to accomplish atomization as opposed top older guns that ran at higher pressures. IME the HVLP guns that are not gravity fed and are not actually pressure assisted with pressurized cups never work well.
The two hose deals with the separate head and pot are usually air over pressure or "air assisted" With most of the spray force derived from fluid pressure and a bit of air fan at the cap to just atomize, not transport the fluid. These are the peak of transfer efficiency and can be dialed in to match product instead of adding reducers and such to make product work with equipment.
Brian
These users thanked the author B. Howard for the post: bionta (Thu Apr 18, 2019 8:53 pm)
PostPosted: Thu Apr 18, 2019 11:41 am
I use a Husky HVLP from Home Depot with a 1.4 mm tip. It basically looks like a standard oldschool spray gun with a gravity feed cup to me. Anyway it works fine. It came with a 1.8 tip also which I have never tried. Some people call them jamb guns too. I think it was around $50.
I don't know what the real expensive guns do differently but since I level sand before buffing anyway I couldn't see a reason to go off for the big bucks. Maybe someone on here can explain the difference.
PostPosted: Thu Apr 18, 2019 12:24 pm
First name: Jason
Last Name: Moe
City: LaCrosse
State: WI
Zip/Postal Code: 54601
Maybe your psi is to high. I spray mine under 30 psi depending on humidity.
Jason Moe
LaCrosse WI 54601
PostPosted: Wed Apr 24, 2019 11:20 am
First name: Leonard
Last Name: Duke
City: Kalamazoo
Zip/Postal Code: 49001
Are you using the best thinner you can get? Better thinners have more of some expensive ingredients that make it easier to get a good flow out. I go to a store for professional finishers and ask for their best lacquer thinner. In balancing all the variables like pressure, gun adjustments, distance of gun from surface, speed of moving the gun, amount of thinner, etc, the good thinner makes it easier to find that "sweet spot" where the finish flows out to a nice gloss and it is easy to avoid runs.
The stuff in the hardware store is only good for cleaning equipment.
PostPosted: Thu Apr 25, 2019 8:26 pm
What Leonard said.
Users browsing this forum: J De Rocher and 46 guests
