Epoxy for FB gluing - Makes?
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=52145
Author:  Colin North [ Sun Jul 07, 2019 12:38 pm ]
Post subject:  Epoxy for FB gluing - Makes?
Thinking to use epoxy for gluing next fingerboard - I have araldite standard (high strength slow cure), have ordered Devcon 2 Ton Epoxy, and can also get BSI here in UK
Never thought to ask here what others recommend - duh
Author:  Barry Daniels [ Sun Jul 07, 2019 12:53 pm ]
Post subject:  Re: Epoxy for FB gluing - Makes?
I use West Systems. Whatever you use do the slow set kind. It usually cures harder than the quick set.
Author:  TimAllen [ Sun Jul 07, 2019 1:09 pm ]
I also use West System slow set, and it works well for me. I mix it by weight: I think the proportion is 3.7 to 1 part hardener. A small digital scale, cheap from eBay (about $15 US), makes it easy to mix even small amounts of epoxy accurately.
Author:  klooker [ Sun Jul 07, 2019 1:40 pm ]
Here's an old thread.
viewtopic.php?f=10101&t=39574&hilit=epoxy
Author:  James Orr [ Sun Jul 07, 2019 3:24 pm ]
I used Smith’s from LMI on my last, but this looks like one more reason to invest in some West.
Author:  Colin North [ Sun Jul 07, 2019 3:54 pm ]
After some research and the replies to this post and others in the archives I think I'm leaning towards the Smiths https://www.makewoodgood.com/product/oak-teak-glue-wood-glue/
Author:  Ernie Kleinman [ Sun Jul 07, 2019 5:19 pm ]
Contrarian here, I/ve used it and have 3 different types and 2 part UF glue . Frankly dont like it, for these reasons , Dont like the smell , , very messy application, and trying to remove it is, hard and cleanup is messy.. Once put on coco fb with epoxy , because of the oils and then had to remove it . Total pita. Your mileage and results will vary. I/ve had better luck using epoxy with a brush or roller for laminated sides . For FB . I prefer fish . long open time , . easy cleanup with warm water , easy to remove fb for repairs. I also use fish for frets , not ca,
