It is currently Sun Sep 21, 2025 10:32 am
 Post subject: Removable Pickguard
PostPosted: Fri Aug 09, 2019 9:58 am
I have a client that is requesting one and he wants Tortoise shell. I've seen the Kling-On electrostatic type guards but they only seem to come in clear or black.
Does anyone have any ideas how to make one from regular tortoise celluloid on a French Polish finish?
I cannot think of anything.
 Post subject: Re: Removable Pickguard
PostPosted: Fri Aug 09, 2019 5:33 pm
First name: Eric
Last Name: Reid
City: Ben Lomond
Zip/Postal Code: 95005
Use the thinnest material you can find. Something like this should work: https://www.stewmac.com/Materials_and_S ... FkEALw_wcB
Use Elmer's white glue to stick it on. Later, you can peel it off without damaging the finish. The remaining glue residue cleans up with white vinegar. This technique is commonly used on flamenco tap plates. It's much more reversible than the self-adhesive material which becomes increasingly impervious to solvents as the years go by.
PostPosted: Sat Aug 10, 2019 11:11 am
First name: Tom
Last Name: Rein
City: Saline
+1 regarding Elmer's on FP. I've used it with thin Mylar. I use a wine cork cut in half to squeegee out the excess glue and air bubbles. It is a little finicky but works great. After 3-4 days the milky appearance disappears. And, if you need to remove it just peel it up. If the pickguard material is dead flat it should work fine. If there is a curl or warp to the PG you might be in for difficulties.
Stay with the happy people.
--Reynolds Large
PostPosted: Mon Aug 12, 2019 9:36 am
Great. thanks for the tips.
