Classical builders - glueing flat bracing on a radius dish
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=52587
Author:  Colin North [ Wed Oct 30, 2019 3:21 am ]
Post subject:  Classical builders - glueing flat bracing on a radius dish
Building a hybrid nylon string -
Anyone gluing flat/un-radiused fan bracing to a soundboard in a solera/radius dish?
Does it hold the radius after drying?
Author:  Clay S. [ Wed Oct 30, 2019 7:52 am ]
Post subject:  Re: Classical builders - glueing flat bracing on a radius di
"Does it hold the radius after drying?"
Yes, it holds the shape - although when I use a solera the arching is not a true radius.
Author:  johnparchem [ Wed Oct 30, 2019 8:24 am ]
I switched to flat braces after my first classical, At a GAL 6 or 9 years ago I heard a talk by Eugene Clark where he suggested keeping the fans unradiused. He said they would spring back about 50% so he makes the dish about 2x deeper. I found this is true but I have found that my 2 mm deep dish still gives me a 2 mm or so dome with string tension. So I switched to flat braces without deepening my dish. My top are relatively thin at 2 - 2.2 mm. A thicker top may have more spring back.
Author:  jfmckenna [ Wed Oct 30, 2019 9:40 am ]
Really? If you just clamp flat braces to the top in a radius dish the top will conform and stay that way? I would have thought it would have sprung back flat.
I've always glued them on flat then glued in the radiused transverse bar.
I wonder what the stress imparted into the top by clamping flat braces to a dish would do to the tone of the guitar?
Author:  jshelton [ Wed Oct 30, 2019 9:42 am ]
Like Clay, my solera is more of a parabola than a dish. I use different configurations and thicknesses of tops and bracing depending of whether it's a classic or flamenco but have always glued flat braces. The tops take the shape of the solera regardless of type of wood, thickness, taper or brace configuration.
Author:  johnparchem [ Wed Oct 30, 2019 9:50 am ]
jfmckenna wrote:
... I wonder what the stress imparted into the top by clamping flat braces to a dish would do to the tone of the guitar?
Even ignoring the braces a radiused top imparts stress, the flat braces pressed into a dish is just an incremental amount of tension. A guitar is all about stress or tension. A bit more pre loading of the top may improve the performance of the top.
Author:  Colin North [ Wed Oct 30, 2019 11:38 am ]
That's what I thought folks, perfect.
Reason I'm asking is this will be a hybrid, nylon strings but bolt-on neck and will be constructed using radius dishes much the same as a steel string.
The soundboard will have a bridge patch, and if I use flat fan bracing it makes taking a check out of the fan braces for it simple.
Have to keep the humidity firmly under control too, winter makes it easier to keep it down.
Author:  Herr Dalbergia [ Wed Oct 30, 2019 2:05 pm ]
One highly regarded guitarmaker for nylon string guitars and lutes here in Germany told me, he is gluing the already curved braces on the top, without using a dish, just on a flat surface. When taken of the clamps, of course the top bends according to the curve on the braces. Also nice....
Author:  oval soundhole [ Thu Oct 31, 2019 1:43 pm ]
The two classical makers I studied under in the south of Spain both glued flat braces to their tops. Stephen Hill even used a 6 meter radius dish to glue the fan braces instead of straight into the solera and used a hair dryer to warp the top prior to brace glueing (apparently it's the Granada secret)
Author:  Pat Foster [ Thu Oct 31, 2019 6:55 pm ]
A well-known builder I know glues his braces flat after the top has acclimated to 8% RH. When the braced top is returned to the main shop with his normal 40-45% RH, the top expands and he gets his dome.
Author:  wbergman [ Fri Nov 01, 2019 6:59 am ]
What thickness of flat braces?
Author:  Colin North [ Fri Nov 01, 2019 7:37 am ]
From what I've seen, talking Classicals, seems to be 6mm or less in height (Courtnall, Making Master Guitars )
Author:  jfmckenna [ Fri Nov 01, 2019 8:17 am ]
When you say flat braces you mean fan braces right? I can't imagine imparting an arch into the fan braces becasue they are so small. I've only built about a dozen classical guitars but I always glued the fan braces on flat and arched the lower transverse brace to give the top it's shape, and strength.
Author:  wbergman [ Fri Nov 01, 2019 11:57 am ]
The very first article I saw on building classicals, the builder shaped the fan brace on the glue side to the desired arch. Each brace was glued with a straight, stiff backer on the brace and a thin flexible backer was used on the top of the guitar, so the top was drawn down to the curve. Regular clamps. No work board was used.
Author:  Mike Collins [ Mon Nov 04, 2019 1:37 pm ]
I glue my 4-5mm tall braces in the go-bar not pre arched.
the top arch holds when removed from the dish.
A The #1 & 2 braces are not glued till the top gets to the solera.
Author:  Colin North [ Mon Nov 04, 2019 5:21 pm ]
Are the #1 & 2 braces transverse braces?
Possibly UTB and a transverse?
Author:  Mike Collins [ Tue Nov 05, 2019 4:25 pm ]
Yes.
#1 is slightly arched .
# 2 is arched to fit the solera .
IT'S NOT THE SAME ARCH AS THE FANS
I use a radial bracing now-all braces below #2 are arched in the go-bar.
same as trad. bracing
Mc
Author:  Colin North [ Tue Nov 05, 2019 6:49 pm ]
THANK YOU.
