Checking FB projection over soundboard at saddle position.
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=52984
Author:  Colin North [ Sun Mar 01, 2020 2:16 pm ]
Post subject:  Checking FB projection over soundboard at saddle position.
Lotsa questions over the years on neck angle, etc., just though I'd post something on it.
This build's a Hybrid and was built with a 28" domed top, flat UTB and started with a flat top rim, so I couldn't do my normal method (straight edge on the upper bout and a drill bit), but worked out something similar.
After some sanding on a flat board with the tail propped up, wanted to verify my calculations, so before gluing the top on checked the FB projection using a 7mm spacer (FB + fret height) over the neck block, held that and the soundboard in place with go-bars and placed a straight-edge on the spacer.
Then measured the height of the straight edge over the saddle position.
Picture below.
Author:  Joe Beaver [ Sun Mar 01, 2020 4:43 pm ]
Post subject:  Re: Checking FB projection over soundboard at saddle positio
Excellent Colin. It is always best to check the angle early on and often during the build. I know this because I've discovered the hard way what can happen if you don't do it!!!
Author:  Fasterthanlight [ Wed Mar 18, 2020 4:36 am ]
Very good idea... out of interest, what hight at the saddle are you shooting for?
Author:  Colin North [ Wed Mar 18, 2020 10:52 am ]
This is a nylon string hybrid, so 13mm, as I lose ~1mm to relief and then there's soundboard pull-up. Ending up about 11.5mm.
For a SS, then depends what I (or the client) want from the sound, but highest is 14mm, lowest could be ~11.5mm.
Author:  johnparchem [ Wed Mar 18, 2020 10:59 am ]
I do the same but only use the fret board thickness. I like the idea of using the fret board plus fret. Then again I assume 1 mm of relief under tension and I have 1 mm fret height, so that part washes it washes anyway.
