X brace height
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=53044
Author:  SnowManSnow [ Thu Mar 26, 2020 5:12 pm ]
Post subject:  X brace height
I’ve seen some pretty fantastic variance in how high ppl like to leave the x brace height before things taper down.
I know tops car vary, but where do you start from?
Author:  Michaeldc [ Thu Mar 26, 2020 6:19 pm ]
Post subject:  Re: X brace height
My x-brace starts @ 1/4"x 5/8". UTB starts @ 5/16"x 13/16". My typical x-brace intersection ends up about 1/2" tall after carving.
Best, M
Author:  Colin North [ Fri Mar 27, 2020 7:33 am ]
Can depend on the type of body OM, Dread, etc but currently I'm using X Braces at 0.256 x 0.550" with very light (SG=.036) stiff spruce for an OM.
Last one turned out just fine.
Author:  jfmckenna [ Fri Mar 27, 2020 8:17 am ]
I am building two OM's now and they are at 13mm, a hair over 1/2in. A dread would be taller, probably a full 5/8th. So yeah, it all depends.
Author:  James Orr [ Fri Mar 27, 2020 4:39 pm ]
5/8" is a very safe number. That's where I start, and end up between 5/8" and 1/2” by the end, depending on the response I'm getting when I tap. I've also moved to tapping with the top glued to the rim before the back is on.
Author:  Woodie G [ Sat Mar 28, 2020 6:19 am ]
Hope this helps...
Note that the center graft starts at 1/8" thickness, but between planing with a skew block plane to remove go-bar dents and shaping, final size is usually at or just over 0.080" maximum thickness.
Author:  Colin North [ Sat Mar 28, 2020 8:13 am ]
Thanks Woodie G, nice timing, I'm replacing a maple BP with a rosewood one on a build and just about to thickness it.
