fretwire crown height http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=53372 |
Author: | phavriluk [ Thu Jul 23, 2020 2:04 pm ] |
Post subject: | fretwire crown height |
I'm keeping my questions segregated from each other... I noticed that the vendor of the fretwire I'm considering offers the same crown width and tang depth on two versions of 'medium' fretwire, .037" and .043". I've used the .043 version on five guitars; what would be the benefits/drawbacks of using the .037 version? For that matter, which of the two is more commonly used? Are these sometimes mixed, as in using the .037 version on frets 14 and higher, for example? Thanks very much. |
Author: | meddlingfool [ Thu Jul 23, 2020 2:54 pm ] |
Post subject: | Re: fretwire crown height |
I would think using the same crown heigh for all frets is the way to go. Taller frets allow more grind and polish before replacement. There is definitely a point where taller is too tall. If they’re too tall, the action will feel high even if the space between top of fret and bottom of string is what you like. I would choose the .043 |
Author: | Chris Pile [ Thu Jul 23, 2020 2:56 pm ] |
.037 is about the shortest you can find, and since medium jumbo seems to be the trend these days - go with that. You wouldn't think .006 makes a diff, but it does. |
Author: | SteveSmith [ Thu Jul 23, 2020 3:39 pm ] |
0.043" gets my vote. Get more milage out of it. |
Author: | Tim Mullin [ Thu Jul 23, 2020 5:06 pm ] |
I can’t imagine a vendor describing a 0.037 or 0.043” tall wire as “medium”. In a width around 0.080”, these heights are on the small side, suitable for vintage guitars, mandos, banjos. A “regular” wire would be something like Jescar 0.047 x 0.095”. “Jumbo” would be wider, and “super Jumbo” both wider and taller. Of course, frets are super personal. I find some factories (e.g., Taylor) use very small frets (that wear out fast), while others (e.g., Ibanez) are massive. Sent from my iPad using Tapatalk |
Author: | TimAllen [ Sun Jul 26, 2020 12:39 am ] |
From a player's perspective, taller fretwire gives you a better hold on the string to bend it or vibrate. Players who don't use these techniques have a "better" opportunity to pull the fretted note out of tune. |
Author: | Clinchriver [ Sun Jul 26, 2020 7:15 am ] |
The .037 is "vintage" Martin fretwire height, .043 is the more modern. Go with the .043, or taller |
Author: | phavriluk [ Sun Jul 26, 2020 12:59 pm ] |
Thanks, everybody. |
Author: | Clay S. [ Sun Jul 26, 2020 4:25 pm ] |
Stew Mac's medium wire is somewhere in the middle at .039. I think it gives a reasonable fret height, but .043 will give you more to work with |
