It is currently Sun Sep 21, 2025 4:51 am
Post new topic Reply to topic  [ 39 posts ]  Go to page 1, 2  Next
 Post subject: Chinese Zipflex purfling
PostPosted: Tue Dec 15, 2020 11:51 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
So I found these zipflex type purfling from China. They really upped their game for sure!
I know many of you would balk at ordering anything from China, but for those of us not in the US it's our only options, because I don't think Depaule has Zipflex. They're also real cheap, 5 dollars gives you enough zipflex to do an entire perimeter of the guitar (this is a Grand Auditorium).
The ziricote back and side set costs me about 150 as well.
This is from their catalog...
Typhoon Guitars
PostPosted: Wed Dec 16, 2020 12:23 am
Looks good from here!
PostPosted: Wed Dec 16, 2020 12:44 am
Good to see you posting again Tai,
Are they using solid shell or ablam for that product?
PostPosted: Wed Dec 16, 2020 12:55 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
It looks like abalam to me. I mean because I see layers from the side. But apart from density differences I don't see any difference in the final product with abalam.
But I bought this abalam from China that only has the first (.010") layer that is abalone and the rest of the layers are all MOP. It sucked real bad because just trying to level sand it after inlay would result in ruined inlay. I'll use it for pieces requiring MOP but I am still trying to track down inexpensive source of abalone shell for laser engraving.
You ever tried to cut chinese characters by hand?
By the way I install purfling and binding in 2 steps because I don't have any fancy binding jigs. So I am using edge guide that came with my router to route the channel. As a result they are not even in thickness (and there is no way I can fix this). So I needed the purfling installed so I can file and fit for binding fit as necessary. It is real time consuming, but I am not getting paid much building guitars and so I can't afford fancy binding jigs.
Typhoon Guitars
PostPosted: Wed Dec 16, 2020 1:40 am
All you need is a set of drawer slides or you can even make a paralellogram with 4 hinges...
PostPosted: Wed Dec 16, 2020 1:45 am
You can just use the hinge part and skip the drawer parts.
PostPosted: Wed Dec 16, 2020 1:46 am
PostPosted: Wed Dec 16, 2020 10:29 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Yea, but the fact is, no matter what I do, wooden binding just fights me every step of the way, no matter how well the binding fits, or how thin it is (so that it is more flexible).
I needed more than 50lbs of pressure to get them to go into position without gaps. Tape will not work. So binding takes a long time because I am actually using clamps to install them, 1 inch at a time.
Typhoon Guitars
PostPosted: Wed Dec 16, 2020 10:41 am
If you want a material that is cheap and relatively easy to install, buy some plastic edge banding and make your own "boltaron' style binding.
PostPosted: Wed Dec 16, 2020 10:51 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Well, I agree and I can find ABS plastic strips cheaply enough (or buy Celluloid from Taobao).
But the reason mass produced guitars use plastic binding is because they're easy to install, however I am not able to get Weldon #16 for the work so I'll use CA.
Maybe if I make a budget line of guitars I'll just use plastic binding and skip wood. Plastic is just so much more forgiving. You can melt it together and not worry about lines. Curly maple is hard, every joint or attachment is visible.
Typhoon Guitars
PostPosted: Wed Dec 16, 2020 11:47 am
If it takes 50lbs of pressure to get your bindings snug, there is clearly something wrong with your process.
These users thanked the author meddlingfool for the post: Colin North (Wed Dec 16, 2020 1:58 pm)
PostPosted: Wed Dec 16, 2020 12:08 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
Would this Chinese zipflex' respond to some encouragement from a heat gun? The side bending mold could be used to monitor progress, and heat guns used in the model airplane hobby don't try to set the world on fire.
Peter Havriluk
PostPosted: Wed Dec 16, 2020 12:15 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
No heat gun is necessary at all.
This stuff is basically segments of shell, and it is very flexible. It comes in a roll as pictured, and you simply unroll it and install it like a piece of flexible purfling. It has a piece of rubber backing that keeps it flexible.
I do not know how the real zipflex respond.
Typhoon Guitars
PostPosted: Wed Dec 16, 2020 12:35 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Wood binding - - - I've bent them to shape over a pipe and in the Fox bender. I can't install them without bending first. Alternatively, I could install thin strips laminated in place, but I found bending first to be most productive.
Peter Havriluk
PostPosted: Wed Dec 16, 2020 2:35 pm
Yes wood binding needs to be bent, just like the sides. I make a little patty of the bindings and purflings and bend them at the same time as the sides...
PostPosted: Wed Dec 16, 2020 3:21 pm
City: Tyler
Tai, I can sympathize with the binding struggle. This post is about a binding jig I built cheap that I find works very well for me.
http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=19253&hilit=+Binding
PostPosted: Thu Dec 17, 2020 3:23 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Actually the Chinese seller has binding router bits that have the correct profile, in different profiles (depending on the purfling you are installing). It cuts binding and purfling channel in one go. It wasn't cheap either, equivalent of 10 USD for a router bit made in China.
I had bent some binding yesterday that sprung back today. I found out that I could bend it back into shape using a heat gun. Maybe I could use a heat gun while fitting bindings on to minimize it fighting me so much?
Typhoon Guitars
These users thanked the author Tai Fu for the post: Pmaj7 (Thu Dec 17, 2020 4:33 am)
PostPosted: Thu Dec 17, 2020 4:34 am
Do you have a link to those bits? Sounds interesting! Does it use a bearing?
PostPosted: Thu Dec 17, 2020 4:46 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
https://item.taobao.com/item.htm?spm=a3 ... 2697394141
This is the Taobao link.
It uses a bearing. The cutter itself cuts the channel for blinding (1.5mm thick) and the purfling, have different bits from 1.5 all the way to 4mm in .5mm increments.
The picture shows how it is used.
They also sell tru channel type jigs.
Typhoon Guitars
PostPosted: Thu Dec 17, 2020 8:43 am
actually plastic is more protective when bumped
wood can be pretty but can also be difficult. I do wood binding at .0625 in I also break the inside corner with fine sandpaper. Then when I get ready to install ( I still find duco acceptable ) I use duco or tite bond depending on the purfling. I hate CA for binding , on some woods it will leave a glue footprint.
Also I use a green 3m tape. The key is to get this wood binding to seat into your grooves the top is easy the back is more problematic that is why I wet it first , this helps it flex and tite bond is not affected by the water.
PostPosted: Thu Dec 17, 2020 10:20 am
I found this handy for the link, no Chinese....
https://www.imoney.my/articles/taobao-shopping-guide#:~:text=First%20download%20and%20install%20Google,your%20Google%20Chrome%20address%20bar.
PostPosted: Thu Dec 17, 2020 10:55 am
Try roping when you do wood bindings. You get a good deal of clamping pressure that way.
As for abalone and pearl products the best place I've found is the Australian Mother of Pearl Supplies company. They have the best prices and the quality is good. You can find all kinds of sheets there to make your Chinese characters.
PostPosted: Thu Dec 17, 2020 11:00 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
For wood binding (which is all I use), I don't use tape any more. I use silicone rubber bands. Big, thick, 1 inch and 3/4 inch wide bands. The guitar sits on a guitar shaped platform (with padding), and there are dowels on the bottom of the platform over which the bands are stretched and anchored. And I use hot hide glue, with some urea mixed in to slow down the gelling. This all works really well.
John is right about cutting back the inside corner a little. This is a miniature version of his advice for setting a dovetail joint. Round over the outside corners that are supposed to fit into inside corners, and everything fits together better.
Regarding bending the wood binding: Just get it close, overbend the waist a little, and it usually works out. Wood is flexible when it is this thin. Get it in the ballpark and let the clamping pressure (in my case, from the rubber bands) do the rest. I just don't like trusting tape to provide that clamping pressure.
PostPosted: Thu Dec 17, 2020 11:29 am
First name: Toonces
Last Name: the Cat
City: New Smyrna Beach
State: FL
Ed is absolutely right here -- if you have to really force the bindings then you are doing something wrong. Additionally, even though glue is quite strong - I wouldn't trust the glue joint. Anything more than a bit of finger pressure to close any gaps and you need to stop -- and rework your process.
1. Going thin is definitely helpful - I recommend .075" as a good starting point.
2. Plates with complex geometry can induce curves that the binding must follow. For example, my guitars are 4.5" at the tail and 3.5" at the heel. The back has a radius of 15'. This means that right around the apex of the upper bout, the binding has to not only bend to shape my body profile but have a concave curve downward as well as rotate inward. Regularly bent bindings will require me to really force the bindings to get them to close on the upper bout region. The curve for the cutaway is even worse.
***The solution is to bend your bindings with a slat that is already profiled to account for the plate geometry. Some folks bend their bindings with their sides already profiled. I created a special template that matches the contour of my sides with a notch at the waist region. I transfer this template to a "spare side" and bend my back bindings with it. I also have a template just for the cutaway portion. The top is flat enough that I can just bend them normally. My spare side is a slat off mahogany I shave off my neck blanks.
Those templates are essential for me to get a good fit on my back bindings. If your guitar has less offset in depth between the tail and heel, then these templates are not as necessary.
These users thanked the author Toonces for the post: Pmaj7 (Fri Dec 18, 2020 1:19 pm)
PostPosted: Thu Dec 17, 2020 2:43 pm
Last Name: Orr
Are you trying to put on wooden binding without bending them first. You need to bend them on a hot pipe to as near the profile of the sides as you can get. You should not need to apply lots of pressure.
