Lighting
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=53998
Author:  ballbanjos [ Thu Mar 04, 2021 9:25 pm ]
Post subject:  Lighting
As I've gotten my newly relocated shop going, I've really noticed deficiencies I have in lighting that I never had (quite accidentally) in the old one. In particular, getting good low-angle light on sanding, spraying, and buffing to really bring out the scratches that are there, but are not necessarily easy to spot. I think that getting good shop lighting for this kind of thing is probably similar to getting good studio lighting for photos. I'm not good at either.
What kind of lighting setups are you using to get good all around lighting for that good low angle, unforgiving view of your work?
Author:  WaddyThomson [ Thu Mar 04, 2021 9:51 pm ]
Post subject:  Re: Lighting
I like LED lighting, but I don't think there is any replacement for well placed incandescent lights for seeing scratches. LED is better than fluorescent, but somehow a good bright incandescent bulb at an angle really makes them pop. At least that's my experience.
Author:  Chris Pile [ Thu Mar 04, 2021 10:24 pm ]
Paint your ceiling white, and the walls a light color.
Author:  J De Rocher [ Fri Mar 05, 2021 12:03 am ]
The light I use for low angle (or any angle really) lighting of close work is a drafting lamp mounted on my bench that has a fluorescent circline bulb and an LED bulb. The combination of the two different types of light sources works well for bringing out details. When I'm doing close work such as sanding, buffing, inlays, binding, fret work, etc., I move the lamp head around frequently while I'm working to get the best lighting angle I need at the moment. It's easy and fast to adjust. It also brings the light source close to the work so the light on the work is quite bright. It's also nice to not have an incandescent bulb in there because they throw a lot of heat. Not a big problem during winter, but not so great on a hot summer day.
IMO, lighting for studio type photos is quite different. For that you want very bright indirect and/or diffused light sources. It also helps if they are easy to move around relative to the subject to change lighting angles.
I general, I favor being able to easily move the light source rather then the object being lit to change the lighting angle.
Author:  Clay S. [ Fri Mar 05, 2021 1:09 am ]
A cheap clip on "hot light" like I used in the photo studio can give you the harsh low angle lighting you need to show up scratches in the finish.
https://www.walmart.com/ip/Bayco-SL-300 ... r/14003467
Author:  doncaparker [ Fri Mar 05, 2021 5:42 am ]
In addition to having two adjacent 48”x24” LED troffer lights over my bench, and a window close by for natural light, I really like having a swing arm lamp temporarily mounted in a dog hole on my bench. It lets me direct the light the way J mentioned. You can get a handy steel bushing with a lip that is made just for this. I made one out of wood before I learned that someone made them out of metal. Very handy.
Author:  bluescreek [ Fri Mar 05, 2021 10:15 am ]
not all leds are the same go to a good lighting store and get an education of light heat
I use 3 lights 4 ft led tubes and coiled lights that are high heat also spot halogens for focus work
I love the new led 4 ft tubes lots of light with a good color spectrum
using different lights allows a wider spectrum. nothing beats sunlight so plan around a window
Author:  ballbanjos [ Sat Mar 06, 2021 8:00 am ]
Thanks for all the suggestions! I think the biggest issue I have compared to my old shop is lack of natural lighting--my old shop was above ground, the new one is in a basement. But I have some good ideas to try out now.
Author:  Dave m2 [ Sat Mar 06, 2021 2:34 pm ]
Almost as an aside I’ve noticed that small LED lights have got quite cheap. I have one that has a magnet on the back and is good for task lighting such as on the bandsaw.
Dave M
