Adhesive backed paper for radius dishes
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=54008
Author:  bcombs510 [ Thu Mar 11, 2021 11:37 am ]
Post subject:  Adhesive backed paper for radius dishes
Hello,
Does anyone know a supplier for the 60 grit cloth backed sandpaper used for radius dishes? I don't need the round one available from the usual suppliers, I need a roll or sheets that are 12" x 16".
Brad
Author:  jfmckenna [ Thu Mar 11, 2021 12:34 pm ]
Post subject:  Re: Adhesive backed paper for radius dishes
I don't use a radius dish but I do use a flat MDF board for sanding and what I found works the best for the price is wide sanding belts that I just cut to fit.
Something like this: https://www.keystoneabrasives.com/categ ... 31B035CBF6
It's not adhesive back but is easy enough to glue down.
Author:  rbuddy [ Thu Mar 11, 2021 12:43 pm ]
You could look at sanding belts for wide belt sanders as a source or call someone like - Klingspor, Woodworkers supply. They may make there own belts and might be able to sell you a roll.
https://www.woodworkingshop.com/product/wb43419/
Thinking and typing the same thing at the same time. Great minds...
Author:  Clay S. [ Thu Mar 11, 2021 2:22 pm ]
I don't know if it is cloth backed, but the dimensions are close:
https://www.homedepot.com/p/DIABLO-12-i ... /202830975
Author:  bcombs510 [ Thu Mar 11, 2021 4:29 pm ]
Hey, that’s a nice find! I can at least try it. In the meantime I ordered a 12” belt to try to cut open as well.
Brad
Author:  bcombs510 [ Thu Mar 11, 2021 5:34 pm ]
Clay, that worked perfectly and for a reasonable price. Thanks for the tip!
If anyone else goes to find these, they were in the tool rental department. At least they were at my Home Depot.
Brad
Author:  Barry Daniels [ Thu Mar 11, 2021 7:35 pm ]
I cut one of my dishes up too. What do you use it for?
Author:  bcombs510 [ Thu Mar 11, 2021 7:56 pm ]
I use this for ukes. It’s 15 on one side, flat on the other. :)
Author:  jfmckenna [ Thu Mar 11, 2021 8:59 pm ]
That's a good find.
Author:  dkrank [ Tue Apr 27, 2021 9:43 pm ]
I'll have to try out the Home Depot option. I see that's a ceramic grain type. For ceramic products I also really like Red Label (https://www.redlabelabrasives.com/collections/ultra-premium-ceramic-sanding-belts). They custom-manufacture abrasives, so they can make them in any size. It might be less convenient than just picking up from the hardware store, but I've found that their ceramic belts last about 2x longer than other ceramic belts I've tried. I've been using these guys as my go-to for abrasives for a few years now. I'll have to test Home Depot's to see how they compare.
Author:  bluescreek [ Wed Apr 28, 2021 6:30 am ]
industrial Abrasives in Reading pa
