It is currently Sun Jul 20, 2025 6:59 pm
Post new topic Reply to topic  [ 46 posts ]  Go to page 1, 2  Next
 Post subject: Bought some Rosewood
PostPosted: Thu Mar 18, 2021 2:29 pm
First name: Richard
Last Name: Hutchings
City: Warwick
State: RI
Zip/Postal Code: 02889
First time ever buying wood like this. I'm going to be cutting for 3 piece backs with my 12" Delta bandsaw. I'll be trimming it to about 5 1/2" before re-sawing the back pieces. I'm hoping I can cut it myself on the bandsaw. Worst case I use my table saw or bring it to a friends house.
Hutch
 Post subject: Re: Bought some Rosewood
PostPosted: Thu Mar 18, 2021 5:34 pm
Nice score!
PostPosted: Thu Mar 18, 2021 7:07 pm
Slow and steady wins the race. Make sure to set your bandsaw up for drift.
PostPosted: Fri Mar 19, 2021 5:53 am
First name: Terry
Yea, if your bandsaw is set up correctly, you should have no problem with a 7" resaw. Of course, a property set up bandsaw is a whole other thread. If I'm about to do a critical cut I like to grab a 4"-5" tall stick of hard maple and see if I can slice a 1/16"-1/32" piece off the side using my fence as a guide. If I get that, I feel like it's ready to go.
Last edited by TerrenceMitchell on Fri Mar 19, 2021 7:56 am, edited 1 time in total.
PostPosted: Fri Mar 19, 2021 7:32 am
Why are you cutting down the back to 5-1/2"?
PostPosted: Fri Mar 19, 2021 8:11 am
Hi Hutch,
I would leave it at the full 7 inch width. When I am using an underpowered 14" Delta I will first deeply kerf both edges of the wood on the table saw using a jig to hold it against the fence, then using the "nail in kerf" method of resawing finish the uncut middle on the band saw (or with a handsaw.
With a 10 inch table saw you can cut 3 inches deep, so by flipping the board you can remove 6 inches of material, leaving only the center inch of a 7" board to be cut with the bandsaw or a handsaw.
I will try to post some pictures of my set up.
PostPosted: Fri Mar 19, 2021 5:20 pm
Last Name: Gleason
City: Kurtistown
State: Hawaii
Zip/Postal Code: 96760
If you can, find someone who uses carbide blades on a larger saw and is experienced at resawing wood thin. If you can, it will be well worth it.
“ The meaning of life is to find your gift and the purpose of life is to give it away” Pablo Picasso
PostPosted: Sat Mar 20, 2021 2:37 pm
Last Name: Beaver
City: Lake Forest
I used a 12" delta for awhile. It was difficult. Motor was too small, a carbide tipped wide blade helped, and it was not easy to get a good setup, but it worked.
Get the best setup you can, being sure to study up on drift. Youtube has some good stuff. (it actually is caused by where the blade lands on the top wheel.) Use a fence and a feather board to hold the bottom against the fence. Then you have to watch the top of the cut as you go. You can put some marks along the top with a gray marker indicating where you want the cut. You can push the top edge of the wood away or against the fence as needed to keep the cut where you want it. Go slow.
Joe Beaver
Maker of Sawdust
PostPosted: Sat Mar 20, 2021 3:29 pm
First name: Carl
Last Name: Dickinson
City: Forest Ranch
Zip/Postal Code: 95942
Hutch,
Checkout the late Ken Cierplowski's thread on Successful Resawing where he cuts the slices off the outside of the blank rather than against the fence. I think it's much easier. http://acousticguitarconstructionforum. ... f=7&t=1819.
PostPosted: Sat Mar 20, 2021 5:28 pm
You could increase your yield by adding "wings" to your backs rather than going three piece.
PostPosted: Sat Mar 20, 2021 6:07 pm
First name: Tom
Last Name: Armstrong
City: Portsmouth
Zip/Postal Code: 23701
Out of curiosity.....what kind of rosewood is this?
PostPosted: Sun Mar 21, 2021 6:06 pm
Here is one way to resaw wood using a table saw.
Raise the blade all the way up and use a jig that holds the blade vertical and against the fence. I use a spring loaded hinge and use the miter slot to hold the jig. Kerf one side then flip the board end for end and kerf the other.
Place the board in the "Hutch" vise and using a rusty hand saw cut out the remaining wood. By the time you are done much of the rust will be gone.
These users thanked the author Clay S. for the post: Pmaj7 (Wed Dec 07, 2022 8:03 pm)
PostPosted: Sun Mar 21, 2021 7:52 pm
sure, you can use a table saw, but you lose a lot of material because of the blade's kerf compared to a bandsaw...and of course one better make sure the blade is really at 0 as even a small error can start to make things rather dicey
as far as blade all the way up in once pass...I'll think I'll pass on that one (hasn't worked too well for me the times I've tried that) and do my usual raise the blade up a bit each pass as I make multiple passes to get to full blade height when I find myself having to resaw woods on my saw
These users thanked the author Mike_P for the post: Pmaj7 (Wed Dec 07, 2022 8:03 pm)
PostPosted: Sun Mar 21, 2021 8:09 pm
Hi Mike,
I agree a large bandsaw is better.
A problem I have had when raising the blade gradually is having the kerf want to close up and cause problems for the second pass. I use thin kerf blades so the loss is not quite as much as with a full thickness blade.
But I do agree a large bandsaw is a better option if you have one available.
These users thanked the author Clay S. for the post: Pmaj7 (Wed Dec 07, 2022 8:04 pm)
PostPosted: Sun Mar 21, 2021 9:22 pm
well, you must have a mighty beefy table saw and uber sharp blades...I do hear you quite clearly on the risks of making multiple passes and admit it has its own drawbacks but at the very least reduces burning/glazing/etc from excess heat
I've tried this on big saws and still not been all that comfortable with one pass at full blade height, but glad to hear you can pull it off with alacrity
PostPosted: Sun Mar 21, 2021 10:28 pm
"...or bring it to a friends house." Best choice.
PostPosted: Mon Mar 22, 2021 5:48 am
Mike,
You have some valid points. The saw is an old Unisaw, with a 1 1/2 hp motor, so nothing special, and the thin kerf blade helps, but still, if I was resawing a lot I'm sure things would heat up.
You have me thinking about putting a small "shark tooth" splitter on the front of a tablesaw insert which could be swapped in for the usual one after the initial pass was made. That would keep the kerf open and allow for multiple passes, raising the blade a little each time, as you suggest.
It would be easier on the saw and perhaps safer.
PostPosted: Mon Mar 22, 2021 8:26 am
First name: Richard
City: Warwick
State: RI
I think I'll get a better yield from 6" wide or less cuts on my bandsaw. I like 3 piece backs so that's not an issue. I'm also considering flamed maple for the center piece. I'm not going to slice it all at once but as needed so I may also try the tablesaw method. Good point about the riving knife which I don't have. I'll look into that before trying it. Absolutely multiple passes for me and my Rigid TS. I forget what the motor is but I don't think it would make single passes too well.
Hutch
PostPosted: Mon Mar 22, 2021 8:28 am
First name: Richard
City: Warwick
State: RI
meddlingfool wrote:
Nice score!
Maybe, it's really going to depend on the yield. I paid $280 for that.
Hutch
PostPosted: Mon Mar 22, 2021 9:02 am
banjopicks wrote:
meddlingfool wrote:
Nice score!
I guess the days of buying cocobolo for $15 a board foot are long gone! [headinwall]
I make table saw inserts out of scraps of Corian because my table saw accepts 1/2inch thick inserts. If the saw only accepts a thin steel insert some people will laminate Formica to a piece of 1/2inch plywood and leave a lip all the way around. This allows them to make a zero clearance insert.
I am going to use a screw about half an inch in front of the maximum height the blade raises to to act as a splitter.
PostPosted: Mon Mar 22, 2021 9:10 am
First name: Richard
City: Warwick
State: RI
It has got to be cheaper somewhere. I just calculated that to $70 by. Crazy
Hutch
PostPosted: Mon Mar 22, 2021 9:28 am
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
For valuable wood to minimize kerf loss, you could always send it to Borson resaw. I’ve not used him, but he has a good reputation.
PostPosted: Mon Mar 22, 2021 10:00 am
For 5 inch wide stuff you could use the 24 tooth 7 1/4 inch diablo circular saw blades to minimize kerf loss and finish up with one of those thin blade Japanese pull saws (I would probably waste a little wood, save a little physical effort, and use a 10 inch blade - but I'm kind of lazy [:Y:] )
PostPosted: Mon Mar 22, 2021 10:19 am
First name: Brad
Last Name: Combs
If you want you can send it to me, I’ll resaw it and keep the set that you’re about to lose to the table saw. ;)
These users thanked the author bcombs510 for the post (total 2): Pmaj7 (Wed Dec 07, 2022 8:09 pm) • banjopicks (Mon Mar 22, 2021 12:19 pm)
PostPosted: Mon Mar 22, 2021 10:37 am
I've done a fair amount of resawing with the 7 1/4" diablo blade, I usually finish up on the band saw - it's quick and, honestly, I don't want to take the time to set up the bandsaw with the resaw blade and all. Guess if I was doing a pricey chunk of wood I would take the time to set up the bansaw idunno
These users thanked the author SteveSmith for the post: Pmaj7 (Wed Dec 07, 2022 8:09 pm)
Users browsing this forum: Chris Ensor and 21 guests
