CA glue for purflings and bindings http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=54125 |
Author: | Colin North [ Wed Apr 28, 2021 6:00 am ] |
Post subject: | CA glue for purflings and bindings |
Who uses CA for purflings AND bindings, and which viscosity/brand of glue do you use? |
Author: | Glen H [ Wed Apr 28, 2021 7:15 am ] |
Post subject: | Re: CA glue for purflings and bindings |
I use ca. I use thin and wick it in after taping the binding/purfling down with stewmac/lmi binding tape. I usually use the Bob smith stuff I pick up at the local hobby shop. |
Author: | Tim Mullin [ Wed Apr 28, 2021 7:43 am ] |
Generally, yes, on most woods, and always with great care to seal when in doubt. CA does unpleasant things to many woods, not just spruce. These days I use Gluboost Ultra thin — first to tack everything in place once firmly tied/taped dry, then again around all joints with tape removed. CA under tape is a PITA, so try to avoid that. Sent from my iPad using Tapatalk |
Author: | jfmckenna [ Wed Apr 28, 2021 7:49 am ] |
I use it on Ivoroid bindings with shell purflings. For wood bindings I use Fish or Titebond. Just make sure that you seal the hell out of the end grain with shellac.... Don't ask me how I know. |
Author: | bcombs510 [ Wed Apr 28, 2021 7:56 am ] |
I also use thin CA, usually from BSI but sometimes Stick Fast because it’s what Woodcraft sells. I like to tack the purfling in place separately, then the binding, then go back after pulling the tape and glue the rest. I would actually like to see someone else do this close up because I feel like I use too much glue. It’s not seeping into the box or anything but still, it feels like too much. I use strips of HDPE to pin the purfling while I tack it in place. It makes the process longer but at least for me prevents surprises. ![]() ![]() Brad Sent from my iPhone using Tapatalk Pro |
Author: | meddlingfool [ Wed Apr 28, 2021 1:21 pm ] |
Never seen ziricote as a top before. Looks real nice! |
Author: | bcombs510 [ Wed Apr 28, 2021 2:05 pm ] |
meddlingfool wrote: Never seen ziricote as a top before. Looks real nice! It turned out pretty well and sounds good to me. It’s warm, full, less high end than spruce. ![]() ![]() Sorry for the off topic ![]() Sent from my iPhone using Tapatalk Pro |
Author: | Woodie G [ Thu Apr 29, 2021 6:39 am ] |
BSI or GluBoost thin, with GluBoost where needed for a quick tack (but usually not, as natural cure is fairly quick on both). BSI thin is perfect for shell work, and will not yellow/discolor over time as will some cheaper CA glues. And just a plug for Mr. Arnold's use of BSI CA Gold or Gold+ for the frequent Martin binding repairs we see...thin enough to penetrate on failing contact cement joints in the afflicted guitars, and much better stick/more permanent repair of peeling Bolteron on 1960's and later bindings. |
Author: | TerrenceMitchell [ Thu Apr 29, 2021 10:23 am ] |
We use Tightbond thin CA for purflings, but we seal the channels with shellac before gluing to avoid yellowing the spruce from glue bleed. Tightbond II for bindings and perflings. |
Author: | Freeman [ Thu Apr 29, 2021 1:21 pm ] |
Water thin (StewMac #10) wicked into the seams after the binding a purfling has been tightlly taped in place. I use a piece of UHMW to hold areas that might need a bit of additional persuasion. Both wood and plastic. I'll add that I have become sensitized to CA and I have to wear a full respirator when I do this but it works so well that I keep doing it. |
