It is currently Mon Jul 28, 2025 5:51 am
 Post subject: Set Up From Hell
PostPosted: Tue Sep 21, 2021 1:31 pm
I cannot for the life of me figure out what is going on here. This is a Taylor builders edition guitar and frankly I was quite surprised at how poorly set up it was. There were at least 5 frets that needed to be glued back down and the action at the nut was really high. Unusual I thought for Taylor. I don't get as much simple set up work as I used to. Most of the guitars I work on now are 19th century guitars but I digress. I used to work for a shop that sold Taylors and was always impressed with the factory set ups. So I got to tuning up the nut and now... Well I guess I see why the action was so high there.
I got the low E string down but no where near as far as I normally go. I use the 3rd fret trick to set the string height. I normally like to let the E and A be a tad tall so that players can bang on open strings. The rest of them go so low you can barely see space over the first fret and you hear that 'tink' when you tap it... You all know what I mean. Well this E string is no where near where I would normally lower it too and it buzzes like hell!
I set the relief to whats considered normal, I set it even more to see if it would stop it and it didn't.
This is a V-Braced guitar. Would that possibly have anything to do with it? I know that sounds desperate but I'm desperate. It makes absolutely no sense. The resonant frequency of the guitar is almost spot on G so it's not an E wolf causeing excessive string vibration.
I've never seen anything like this before and I'm loosing money on this dawg!
 Post subject: Re: Set Up From Hell
PostPosted: Tue Sep 21, 2021 1:35 pm
Pics would really help to diagnose this. Can you post some up?
PostPosted: Tue Sep 21, 2021 1:37 pm
I can do that later. What exactly of? What angle? And so on?
PostPosted: Tue Sep 21, 2021 1:40 pm
Fret rocker? Check for a high fret end.
These users thanked the author Colin North for the post: Pmaj7 (Wed Sep 22, 2021 10:32 am)
PostPosted: Tue Sep 21, 2021 1:43 pm
Neck angle projection over the body, just put a straight edge on the neck and see if there's a V shape between frets 1-14 and the fingerboard extension.
Saddle height
Relief with a straight edge
As a side note, see if your low E has a dent in it, it'll be obvious if it does, and if it does replace it and see if your buzzing goes away.
PostPosted: Tue Sep 21, 2021 1:56 pm
Ok Dan. I'll see about that later...
I did fret rock it, that's how I found all the high frets, well that and the buzz. Couldn't believe it really!
PostPosted: Tue Sep 21, 2021 2:21 pm
First name: Pierre
Last Name: Castonguay
City: Québec, Qc
I've had quite a few Taylors with one or two high frets at or next to the body joint. Not yet sure why… excessive dryness, bad QC or even some cause related to the neck joint mechanics...? Anyway, once taken care of, all is back to normal.
Pierre
Guitares Torvisse
Pierre Castonguay
These users thanked the author Smylight for the post: jfmckenna (Tue Sep 21, 2021 2:36 pm)
PostPosted: Tue Sep 21, 2021 3:17 pm
No surprise to me. Taylors ain't all that. If they were really good, I'd own one.
These users thanked the author Chris Pile for the post (total 3): Dave Rickard (Wed Sep 22, 2021 7:28 am) • joshnothing (Tue Sep 21, 2021 10:14 pm) • jfmckenna (Tue Sep 21, 2021 6:13 pm)
PostPosted: Wed Sep 22, 2021 10:36 am
You need to level the Frets to rule that out. Especially if you had loose frets.
But first, check for a ski ramp, I've had that cause open string buzzing on the E before.
These users thanked the author Pmaj7 for the post: jfmckenna (Wed Sep 22, 2021 10:46 am)
PostPosted: Wed Sep 22, 2021 10:45 am
Problem solved. I had to set the relief to .017. A hair under that and it would buzz like hell. I don't normally set the relief past .01 but I guess some guitars...? It also needed a lot of fret work. Very disappointing to see on a $3k guitar. And it was not just high frets, there were a few of those, but the frets from about 13 to the end of the board were all set tight to the fretboard but they were just not leveled properly. This being a cut out guitar too.
Not this is a big deal but it does sort of indicate that they are in a bit of hurry or something but look what they left in the truss rod cavity.
These users thanked the author jfmckenna for the post (total 3): Hesh (Thu Sep 23, 2021 4:03 am) • DanKirkland (Wed Sep 22, 2021 2:54 pm) • Chris Pile (Wed Sep 22, 2021 11:08 am)
PostPosted: Wed Sep 22, 2021 12:07 pm
First name: Conor
Last Name: Searl
City: Duncan
State: British Columbia
Zip/Postal Code: V9L 2E5
Had the guitar dried out?
.017" is a lot of relief (as I'm sure you know). I've found too much relief can cause as much buzzing as not enough relief. But obviously that's not the case with this one if you're happy with the relief.
For what its worth in my limited experience mystery buzzes are generally a bad string (even if its new) and once that's ruled out it's almost always a fretwork issue.
