Double sides bending question… http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=55055 |
Author: | meddlingfool [ Wed Jun 08, 2022 5:14 pm ] |
Post subject: | Double sides bending question… |
Anybody try bending two at a time, stacked on top of each other in the order they’re to be laminated? |
Author: | Colin North [ Wed Jun 08, 2022 5:31 pm ] |
Post subject: | Re: Double sides bending question… |
Maybe not the answer to your question, but Micheal Greenfield bends and glues his laminated sides together at the same time |
Author: | meddlingfool [ Wed Jun 08, 2022 6:29 pm ] |
It’s sorta the answer…anyone else? |
Author: | meddlingfool [ Wed Jun 08, 2022 6:57 pm ] |
Saw that part of the doc but he was bending the sides as singles… |
Author: | Terence Kennedy [ Thu Jun 09, 2022 5:47 pm ] |
I have done double sides for probably 12 years and always bend both together. No issues. Makes laminating them easier because they fit perfectly. I always profile first and am careful that everything is lined up perfectly. |
Author: | meddlingfool [ Thu Jun 09, 2022 5:50 pm ] |
Thanks Terence, Does that include cutaways? What thickness are you bending your lams? |
Author: | Joe Beaver [ Thu Jun 09, 2022 6:57 pm ] |
I have only done it once. Does that qualify me as an expert? I bent the inside piece first, then left it in the bender and bent the outside piece. I did wrap the inside piece after it was bent with wet paper and tin foil to keep it from getting too hot. They fit together well so I glued on the bender. |
Author: | Terence Kennedy [ Thu Jun 09, 2022 8:33 pm ] |
meddlingfool wrote: Thanks Terence, Does that include cutaways? What thickness are you bending your lams? I have bent archtop cutaway sides together, maple and mahogany. No flat tops. Thickness is around .060 outer and .040-.050 inner. My setup uses two blankets. The sandwich is slat/blanket/slat/moist paper/both sides /paper/slat/ blanket. The moistened sides are profiled and the waist carefully marked. They stick together pretty well when moist and are cut to the same length and profiled on the same template so they line up well. Sandwich is clamped together with spring clamps and placed in the bender lining up the waist. Bending is routine and no issues or broken sides so far (fingers crossed!) Here are some photos that show the profiled sides (Mahogany outer Rosewood inner), assembling the sandwich, placing it in the bender and removal and placing on the laminating form. ![]() ![]() ![]() ![]() ![]() |
Author: | meddlingfool [ Fri Jun 10, 2022 12:08 am ] |
Thanks, that gives me something to chew on… |
Author: | Barry Daniels [ Fri Jun 10, 2022 8:05 am ] |
I bend my double sides separately because I only have a single heating blanket on one side. |
Author: | bcombs510 [ Fri Jun 10, 2022 8:44 am ] |
FWIW - I bend lining three layers thick at the same time. Each is .065” and I bend with a blanket on top and bottom. The wood is 4” wide and as long as needed for the body shape. I made a bending form that is reduced by .285 from the outside mold so the lining nests into the side really well. Once I switched to two blankets the top piece held it’s shape a lot better. Sent from my iPhone using Tapatalk Pro |
Author: | Colin North [ Fri Jun 10, 2022 10:03 am ] |
bcombs510 wrote: FWIW - I bend lining three layers thick at the same time. Each is .065” and I bend with a blanket on top and bottom. The wood is 4” wide and as long as needed for the body shape. I made a bending form that is reduced by .285 from the outside mold so the lining nests into the side really well. Once I switched to two blankets the top piece held it’s shape a lot better. Sent from my iPhone using Tapatalk Pro And what wood are you using Brad? |
Author: | bcombs510 [ Fri Jun 10, 2022 6:38 pm ] |
I’ve done both white oak and paulownia this way. Mostly paulownia since that’s what I use for ukes and that’s all I’ve been building for the last year. ![]() Sent from my iPhone using Tapatalk Pro |
