SURVEY: Bridge Slotting Q
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=55199
Author:  Chris Ensor [ Wed Aug 17, 2022 2:48 pm ]
Post subject:  SURVEY: Bridge Slotting Q
How thick is your bridge when you slot it? (Example: finished thickness- around 3/8", raw stock- 1/2" +, etc)
Thanks.
Author:  J De Rocher [ Wed Aug 17, 2022 3:09 pm ]
Post subject:  Re: SURVEY: Bridge Slotting Q
Raw stock ranging from about 3/8" to about 7/16" thick.
Author:  bobgramann [ Wed Aug 17, 2022 4:08 pm ]
I slot mine before I cut it out of the blank at just a bit more than finished thickness which is usually around 3/8”.
Author:  Tim Mullin [ Wed Aug 17, 2022 5:22 pm ]
+1
Author:  DennisK [ Wed Aug 17, 2022 5:43 pm ]
3/8 to 7/16. I drill the pin holes and route the slot, then taper the thickness from the back so the slot and holes are tilted back a few degrees, to counterbalance the forward rotation under string tension.
Author:  SteveSmith [ Wed Aug 17, 2022 6:21 pm ]
I route the slot after the bridge is on the guitar. Started doing that after I started doing repairs and got used to it. My bridges are usually about 3/8" like most.
Author:  meddlingfool [ Wed Aug 17, 2022 6:42 pm ]
3/8 + 1/32. The 1/32 gets sanded off when I match the bridge bottom to the top radius, for a 3/8” finished bridge…
Author:  jfmckenna [ Wed Aug 17, 2022 6:59 pm ]
Wiggle room is always nice but I generally aim for a slightly thicker than 3/8th inch block before routing out.
Author:  bcombs510 [ Wed Aug 17, 2022 8:01 pm ]
I think I’m the same as Ed. It’s all done on the CNC but the block is .400.
Author:  Clay S. [ Wed Aug 17, 2022 8:14 pm ]
As Steve mentioned I rout the slot after the bridge is glued to the top. Bridge thickness 5/16ths to 7/16ths inch.
