White spots on redwood http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=55445 |
Author: | Gary Davis [ Mon Jan 09, 2023 8:55 am ] |
Post subject: | White spots on redwood |
Greetings from Montana. I thinned my intended redwood soundboard too much and am looking at another set I have. I'm wondering about these white spots. Lots of research yielded little. My only guess at this point is salt efflorescence. This set came from California and is supposedly forest salvage. Salt from the ocean? I'm not saying they are uniformly through the sample but are present on both sides and both pieces. I assume these deposits will affect finishing. What about tone? Any ideas or further research tips would be greatly appreciated. Gary Davis ![]() |
Author: | Colin North [ Mon Jan 09, 2023 9:33 am ] |
Post subject: | Re: White spots on redwood |
Look like mineral deposits. If it is ocean salt deposits water should remove them, so I would try that first. If it's mineral deposits, see video https://www.youtube.com/watch?v=PGF0FohKcE8&t=88s But you must test it outside the plate outline you're using it, and don't use a wire brush on redwood. Apparently it's not uncommon in domestic redwood https://www.lmii.com/blog/2016/05/08/dealing-with-mineral-deposits-may-2016/ where it says they may disappear under shellac which is easily tested on an offcut/spare bit. |
Author: | Gary Davis [ Mon Jan 09, 2023 12:07 pm ] |
OK - thanks for that. I did try some water yesterday (and sandpaper). Not much happened. I'll give it a better shot next time I'm at the shop. If its salt, I'm assuming it would taste salty or would that be a dangerous thing to do-to taste it? Gary |
Author: | Mike Collins [ Mon Jan 09, 2023 12:13 pm ] |
how thick is the top? Is it thick enough to sand it down without messing it up? 3/16 is fairly normal for suppliers. sand with a palm sander in a spot that will NOT be in the guitar shape. Mike |
Author: | Pat Foster [ Mon Jan 09, 2023 2:08 pm ] |
Muriatic acid has worked for me on EIR with white spots. Might be worth a try, though it's nasty stuff. Take precautions. |
Author: | bluescreek [ Tue Jan 10, 2023 8:44 am ] |
CLR us what I use to remove mineral deposits. |
Author: | Gary Davis [ Tue Jan 10, 2023 10:20 am ] |
OK y'all. Thanks. I may get a chance to go over today. I'll report what I find. Gary |
Author: | Gary Davis [ Wed Jan 11, 2023 8:35 am ] |
I checked it out a bit more yesterday. There are just too many spots. Water seemed to do nothing. I'll just get another set - hopefully without spots. Any recommendations for acquiring another redwood soundboard? [[url][url=https://flic.kr/p/2oaQmtQ] ![]() Gary Davis |
Author: | bobgramann [ Wed Jan 11, 2023 9:19 am ] |
I have bought some good sets from Vince Strauss https://www.pacificcoastwoods.net/. |
Author: | Michaeldc [ Wed Jan 11, 2023 9:33 am ] |
Gary Davis wrote: I checked it out a bit more yesterday. There are just too many spots. Water seemed to do nothing. I'll just get another set - hopefully without spots. Any recommendations for acquiring another redwood soundboard? [[url][url=https://flic.kr/p/2oaQmtQ] ![]() Gary Davis Did you try CLR as per John's recommendation, or only water? Thanks, M |
Author: | Gary Davis [ Wed Jan 11, 2023 10:12 am ] |
Only water. I'll try the CLR. Gary |
Author: | DennisK [ Wed Jan 11, 2023 10:34 am ] |
This sinker set had some white spots, but they pretty much disappeared when coated with shellac. Attachment: Before.jpg Attachment: After.jpg Pour a pool on it and push it around so it can really soak in before it dries. The initial shellac application makes a big difference to the appearance. If the initial coat is done with a fairly dry cloth, it will create a thin film just on the surface and prevent further coats from penetrating. Useful for preventing endgrain from darkening, but in this case we want to see if the mineral spots go clear when fully wetted. And deeper penetration usually looks better on soundboards anyway. |
Author: | J De Rocher [ Wed Jan 11, 2023 12:35 pm ] |
Gary Davis wrote: Any recommendations for acquiring another redwood soundboard? Gary Davis Felly Smith at Fiddleback Woodshack in Bend, OR is a good source for nice redwood tops. He doesn't have sets posted on his website right now, but he's going been doing several runs of very nice redwood tops and posting about them as he does them on Instagram. I think they've been selling too fast to be worth putting up on his website. I recently bought several sets from him. If you contact him, he'll send you photos of top sets that are available. Felly's a good guy to deal with. http://www.fiddlebackwoodshack.com/products.php?id=2 |
Author: | Gary Davis [ Fri Jan 13, 2023 7:30 am ] |
Thanks Jay. I've acquired a few pieces from Fiddleback. I'll contact him. Thanks for the images Dennis. I think I'll get another set and experiment with this one. I'll mix up some shellac. Gary |
