It is currently Fri Sep 19, 2025 12:04 am
 Post subject: SURVEY: Tuner Spacing
PostPosted: Tue Jan 24, 2023 3:02 pm
Last Name: Ensor
City: Springfield
State: Missouri
2 questions:
- How far apart do you space your tuners?
- How far from the edge?
Thanks in advance.
http://elevatelutherie.com
http://ensorguitars.com
PostPosted: Tue Jan 24, 2023 3:11 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
for a steel string?
Mike Collins
PostPosted: Tue Jan 24, 2023 4:05 pm
Last Name: Colbert
City: Anacortes
Generally, 1-1/2” apart north to south. On a 3 on a side head with straight sides (Martin) I do 1/2” on ADGB and 7/16” on E and E, like a Martin. Snake-head tuner edge spacing is 1/2” E to E. My drug of choice tuners for reference are Gotoh 510 minis.
M
These users thanked the author Michaeldc for the post: Pmaj7 (Tue Jan 24, 2023 5:41 pm)
PostPosted: Tue Jan 24, 2023 4:59 pm
First name: Trevor
Last Name: Gore
City: Sydney
There are a lot of dependencies:
Shape of buttons
Shape/curvatures of the head stock
Mounting square to the centreline or square to the headstock edge
Straight-through string pull or not
6 string or 12 string
Size/style of tuner body (open gear, sealed/cast body)
etc.
I asked the question of Hosco once, for a specific style of Gotoh tuner, as the drawing wasn't sufficiently dimensioned to be able to figure it out. Hosco referred the question to Gotoh, whose response was "we are not luthiers..."
Basic rule: don't drill the tuner holes until you've had them in your hand.
http://www.goreguitars.com.au
These users thanked the author Trevor Gore for the post: Pmaj7 (Tue Jan 24, 2023 5:40 pm)
PostPosted: Tue Jan 24, 2023 5:24 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
I owned a Martin D35 and D12-28 when I started building. I designed my headstock shape starting with the Martin proportions and changed the top. The tuner spacing was also as for Martin, where the 1st and 6th are set in from the edge just a bit less than the others. Did the same thing for my 12s. Can provide exact measurements if someone really cares.
PostPosted: Tue Jan 24, 2023 5:43 pm
First name: Marcus
Last Name: Bailie
City: Kirkland
1.5" apart, 0.5" from the edge.
-Marcus
http://www.bailieguitars.com
Instagram | YouTube
PostPosted: Tue Jan 24, 2023 6:18 pm
Last Name: Kincheloe
1.25" apart, 0.5" from the edge.
But 1.375" apart might be a better choice, because that appears to be the standard for 3-on-a-plate tuners.
