It is currently Tue Jul 22, 2025 11:41 am
PostPosted: Wed Mar 01, 2023 10:07 am
Last Name: Colbert
City: Anacortes
or how much wood do you like to leave under the saddle? I’m not a fan of under-saddle pickups, so that doesn’t need to be factored in.
Thanks, M
PostPosted: Wed Mar 01, 2023 10:44 am
2/3rds of the saddle is sunk in the bridge. This is not a rule mind you but what I shot for with my builds and then later in life in the professional repair scene others told me they do this too, 2/3rds of the saddle below the surface of the bridge.
Wanted to add Michael if you don't mind. Had a Guild in the other day that needed a shim under the saddle (that's all the budget there was not a shim fan here...) and even a .032" shim made the saddle lean forward under string tension a noticeable amount. Had Guild milled their saddle slot deeper this would not be the case.
These users thanked the author Hesh for the post (total 4): Robbie_McD (Thu Mar 02, 2023 7:51 am) • Pmaj7 (Wed Mar 01, 2023 1:00 pm) • Michaeldc (Wed Mar 01, 2023 10:55 am) • rbuddy (Wed Mar 01, 2023 10:53 am)
PostPosted: Wed Mar 01, 2023 10:47 am
Good question, and frankly - one I've never given a thought to in my 45 years at the bench. Obviously, I should have been thinking about it.
These users thanked the author Chris Pile for the post: Michaeldc (Wed Mar 01, 2023 10:55 am)
PostPosted: Wed Mar 01, 2023 11:06 am
City: U.P.
Hesh wrote: "2/3rds of the saddle is sunk in the bridge. This is not a rule mind you but what I shot for with my builds and then later in life in the professional repair scene others told me they do this too, 2/3rds of the saddle below the surface of the bridge."
Same here, 0.10 to 0.125 under saddle. Bridge starts out ~3/8" tall, saddle slot 1/4" deep, saddle ~3/8".
Brian R, Wood Mechanic
N8ZED
These users thanked the author rbuddy for the post (total 2): Hesh (Thu Mar 02, 2023 12:47 am) • Michaeldc (Wed Mar 01, 2023 11:08 am)
PostPosted: Wed Mar 01, 2023 11:07 am
Last Name: Colbert
City: Anacortes
I think it’s also important to place the saddle far enough back from the leading edge of the bridge to make it less likely for the saddle slot to break/crack. I hold mine back about 1/8”- 3mm measured from the treble side.
Thoughts?
Hesh: Thanks for the 2/3 guideline.
These users thanked the author Michaeldc for the post: Hesh (Thu Mar 02, 2023 12:47 am)
PostPosted: Wed Mar 01, 2023 11:38 am
First name: Brad
Last Name: Combs
I make the bridge .400” height on the CNC with a .250” saddle slot.
Once the bridge is sanded and the underside sanded to the shape of the top it is ~.375”. That leaves me a .375” bridge height with .250” slot depth and .125” saddle exposed = .5” string height above the top.
Which is 2/3 below and 1/3 above to Hesh’s specifications! :)
These users thanked the author bcombs510 for the post (total 4): Hesh (Thu Mar 02, 2023 12:48 am) • Pmaj7 (Wed Mar 01, 2023 10:08 pm) • Durero (Wed Mar 01, 2023 3:20 pm) • Michaeldc (Wed Mar 01, 2023 11:42 am)
PostPosted: Wed Mar 01, 2023 1:30 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
steel string -or classical?
Mike Collins
PostPosted: Wed Mar 01, 2023 1:36 pm
6 mm for a steel string in a 9.5mm bridge
These users thanked the author Colin North for the post (total 3): Hesh (Thu Mar 02, 2023 12:48 am) • bcombs510 (Wed Mar 01, 2023 2:49 pm) • Michaeldc (Wed Mar 01, 2023 2:03 pm)
PostPosted: Wed Mar 01, 2023 1:39 pm
I make mine 6.5mm deep just in case someone future drops an under saddle PU in there. Sorry for mixing metrics but beyond that I’m standard issue…3/8 bridge height with just a hair over 1/2 string height at bridge…
These users thanked the author meddlingfool for the post (total 2): Hesh (Thu Mar 02, 2023 12:48 am) • Michaeldc (Wed Mar 01, 2023 2:02 pm)
PostPosted: Wed Mar 01, 2023 2:04 pm
Last Name: Colbert
City: Anacortes
Either one, though I tend to build mostly SS.
PostPosted: Wed Mar 01, 2023 2:47 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
Distance down from the top of the bridge, I think, is a specious dimension. Bridges vary widely in height. I think, leaving room for adjustment, that the saddle slot account for string height above the soundboard, that magical half-inch, for example. Or a builder could decide that his bridges will have 1/8", approximately, of wood beneath the saddle, always. However thick the bridge is, says me, is irrelevant to the saddle's controlling string height. Says amateur builder me.
Peter Havriluk
These users thanked the author phavriluk for the post: Michaeldc (Wed Mar 01, 2023 3:00 pm)
PostPosted: Wed Mar 01, 2023 6:44 pm
I am around 7/32 depth on an 11/32 bridge. Frequently if a shim is needed and there is concern about a tilting saddle I just glue the wooden shim to the saddle so they function as a unit. Easy to sand off if removal is needed later.
I read somewhere that Mark Blanchard puts like a 1/32” shim in his new guitars so as they settle in lowering the action is easy. Anyone around here do that?
Last edited by Terence Kennedy on Thu Mar 02, 2023 9:18 am, edited 1 time in total.
These users thanked the author Terence Kennedy for the post (total 4): Pmaj7 (Thu Mar 02, 2023 2:01 pm) • Robbie_McD (Thu Mar 02, 2023 7:53 am) • Hesh (Thu Mar 02, 2023 12:49 am) • Michaeldc (Wed Mar 01, 2023 6:56 pm)
PostPosted: Thu Mar 02, 2023 4:15 am
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
I agree with the principle that Hesh put forward - and I see other saying essentially the same. There is a problem if the saddle slot ends up too shallow in the total bridge thickness. This happens when a UST gets dropped in the slot, or if the overall bridge height gets reduced in an effort to delay a neck reset. Those of us building new guitars should anticipate these future developments and build a guitar with a deep enough slot to accommodate future needs.
These users thanked the author Mark Mc for the post: Hesh (Thu Mar 02, 2023 8:01 pm)
PostPosted: Thu Mar 02, 2023 7:34 am
I want about .125 under the saddle slot to the top for structure
so normally I do a .325 thick bridge shooting for about .150 to .180 saddle height above the bridge, you can adjust the bridge before you glue it on. I use about 12 lb of weight to get a read on how much my neck will flex. Then I can guesstimate about a 1/16 rise on the top.
Now remember the top of the bridge may have a radius so we are talking about the thickest part.
so martin standard is about 1/2 and 1/2 they like as much in the bridge as out.
.325 thickness -.125 under the saddle is .200 saddle slot depth , and if you have a saddle of .18 you have more in the slot than exposed.
also there is the mechanics of the saddle slot , how close to the front break angle and so on. How well it fits ect.
the deeper the slot and the closer to the front of the bridge the more prone to bridge blow out .
If you do 2/3 and you want .18 saddle height. you would need a bridge over .420
These users thanked the author bluescreek for the post (total 4): Hesh (Thu Mar 02, 2023 8:03 pm) • Gasawdust (Thu Mar 02, 2023 9:27 am) • Terence Kennedy (Thu Mar 02, 2023 8:33 am) • Michaeldc (Thu Mar 02, 2023 7:36 am)
PostPosted: Thu Mar 02, 2023 10:56 am
It's not a bad idea. I've sent them off with two saddles in the past but a shim is certainly an easier option. In some circles though, you use the word 'shim' and people lose their minds even though they would never hear the difference they think they do ;)
I too like to leave 1/8th wood under the saddle and since I go for a 3/8th in bridge I guess I follow the rule of 3rds too.
These users thanked the author jfmckenna for the post (total 4): Hesh (Thu Mar 02, 2023 8:04 pm) • Terence Kennedy (Thu Mar 02, 2023 2:26 pm) • doncaparker (Thu Mar 02, 2023 11:53 am) • Michaeldc (Thu Mar 02, 2023 11:01 am)
PostPosted: Thu Mar 02, 2023 11:57 am
One thing we are missing in this discussion is over all string height at the front of the bridge
I shoot for 1/2 so I am about less than 2/3
These users thanked the author bluescreek for the post: Hesh (Thu Mar 02, 2023 8:04 pm)
PostPosted: Thu Mar 02, 2023 5:22 pm
I've got an early 1970s Guild D-55 that I bought new, and the saddle goes right through the bridge and rests on the top. I always figured a sixteenth of an inch left in the bottom of the bridge should be good.
These users thanked the author bftobin for the post: Michaeldc (Thu Mar 02, 2023 6:08 pm)
PostPosted: Thu Mar 02, 2023 8:03 pm
Yep AND be sensitive to the sizes of commercial saddle blanks too. Don't want to go deeper than blanks are available either. We have seen some newer guitars with the saddle slot essentially being a hole in the saddle and the saddle sat on the top. This required a 1/2" high saddle blank...
PostPosted: Thu Mar 02, 2023 8:12 pm
I'm not sure which is worse the Luthier who sticks their chest out and and declares "I don't use no stinkin sh*ms...." or the client who read on the Internet... that sh*ms are bad but they have no real idea if or why this may be true and really.... neither do we..
Shims can be an excellent solution that fits for lots of reason and certainly meets the reversibility requirement of my own desire for serviceability and reversibility especially when the budget is not there for a nice, custom made, individually compensated bone saddle.
Not all shims are created equally either. I'm fond of using the same material as the bridge for my shims, truing up the bottom of the saddle slot and truing the bottom of the saddle on a surface plate. I can see where a shim can be an improvement tonally for those stoned enough to believe they can hear a difference when I consider how poorly factory saddle slot bottoms are milled.
Whatever. :)
These users thanked the author Hesh for the post (total 2): jfmckenna (Fri Mar 03, 2023 9:38 am) • Durero (Thu Mar 02, 2023 10:14 pm)
PostPosted: Fri Mar 03, 2023 10:37 pm
"Martin standard"? We see their bridge thicknesses all over the map, right out of the factory. Yes for the same models. Standard is probably a misleading term in this case.
PostPosted: Sat Mar 04, 2023 12:03 pm
Supposedly, they choose the appropriate bridge thickness as part of fine tuning their neck angle.
PostPosted: Sat Mar 04, 2023 10:22 pm
Said another way, they haven't figured out how to control their neck angle, so they just fit different size bridges on. Yup ... seen that for a long time. Wouldn't recommend that as a "fine tuning" best practice ;-). Figuring out how to actually control neck angle is far better.
PostPosted: Sun Mar 05, 2023 4:09 am
On a larger scale it’s actually much harder than you’d think.
PostPosted: Sun Mar 05, 2023 6:35 am
Martin changed the floor specs through the years.
They are a production company and thus they have +/- specs. They use 4 different sizes of bridge on the production floor 1/32 apart
the max height is .410 min is .325 then the operator may tweak the bridge . They use a go no go gauge and as long as the part falls into the its good.
They must be doing something right. They do the neck angle now all by CNC and plec . I think they did better when it was done by hand. Plec is not better then a well trained hand its cheaper
These users thanked the author bluescreek for the post: Michaeldc (Sun Mar 05, 2023 11:30 am)
