Fret tang width . http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=55852 |
Author: | BlindGuitar [ Sun Aug 27, 2023 1:35 am ] |
Post subject: | Fret tang width . |
So , my first actual newbe question . After cutting the fret slots with a .53mm Pax saw , I have come to realise that all the fret wire I have is .71mm tang width . Exactly what size tang fret wire should I be using ? My first build used a precut finger board with .71mm slots . Something I didn't even consider when buying fret wire . |
Author: | Colin North [ Sun Aug 27, 2023 2:11 am ] |
Post subject: | Re: Fret tang width . |
At 0.71 mm width I think you're actually talking the width across the tips of the barbs. https://jescarmusic.com/pages/fret-wire-specifications 0.53 mm slot should be good for most tangs, just slightly larger, although it's best to check before cutting slots, some are larger, DAMHIK. The barbs bite into the wood to secure them in the slot. |
Author: | BlindGuitar [ Sun Aug 27, 2023 3:03 am ] |
Yeah , these frets are .71 at the tang and .96 across the barbs . Others I have are .58 and .86 which I bought ready cut and trimmed. I think they might fit if I have enough . Cheers . |
Author: | Colin North [ Sun Aug 27, 2023 5:59 am ] |
OK. That's a pretty big tang width.... |
Author: | Clay S. [ Sun Aug 27, 2023 6:07 am ] |
BlindGuitar wrote: Yeah , these frets are .71 at the tang and .96 across the barbs . Others I have are .58 and .86 which I bought ready cut and trimmed. I think they might fit if I have enough . Cheers . Colin North wrote: OK. That's a pretty big tang width.... The thicker tang might be good for doing refrets on guitars that have been refretted a few times and have worn out fret slots. ![]() |
Author: | Dave Rickard [ Sun Aug 27, 2023 10:18 am ] |
Do we need a zero after the point? maybe .071 instead of .71 and .096 instead of .96. |
Author: | bcombs510 [ Sun Aug 27, 2023 10:19 am ] |
Dave Rickard wrote: Do we need a zero after the point? Puts a new spin on “jumbo” don’t it? Sent from my iPhone using Tapatalk Pro |
Author: | rbuddy [ Sun Aug 27, 2023 10:26 am ] |
I think they are using that alien metric system. Glad Windows 10 has a built in calculator with a conversion tool. 0.71mm = 0.028" |
Author: | bcombs510 [ Sun Aug 27, 2023 10:37 am ] |
rbuddy wrote: Glad Windows 10 has a built in calculator with a conversion tool. I did not know that! Thanks for the tip! ![]() Sent from my iPhone using Tapatalk Pro |
Author: | BlindGuitar [ Sun Aug 27, 2023 6:12 pm ] |
Dave Rickard wrote: Do we need a zero after the point? maybe .071 instead of .71 and .096 instead of .96. Not with Metric we don't . |
Author: | Hesh [ Mon Aug 28, 2023 9:22 am ] |
Where is your wire from and what is the part number? Frets should fit the slot with moderate pressure but not be too tight. If they are too tight they force the neck into back bow which is yet another reason to always use a quality double action truss rod. It's common for us to press one fret in just to observe the fit and then adjust accordingly. In the Martin guitar world, vintage Martins before the early 70s did not have truss rods so the neck is manipulated in its shape with every fret installed with a different tang width. Can't remember if there are 5 or 7 Martin tang sizes we have them all so when a fret fits too snug and I want to avoid back bow I can go to a narrower tang. |
Author: | Dave Rickard [ Mon Aug 28, 2023 4:48 pm ] |
BlindGuitar wrote: Dave Rickard wrote: Do we need a zero after the point? maybe .071 instead of .71 and .096 instead of .96. Not with Metric we don't . DOOOH. My bad. Next time I'll try actually reading what the OP says before I post! |
