It is currently Mon Jul 21, 2025 7:36 am
PostPosted: Fri Jan 05, 2024 8:35 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
Some folks live in a Baltic Birch plywood desert. If you have that problem, but would like to have some for jigs, workboards, etc., I can recommend this outfit:
https://makerstock.com/
I have no connection with them, other than I can report having ordered some BB plywood from them, and what arrived was high quality, flat as flat gets, and packed very well to avoid dings. I ordered four pieces of 24” square, 18mm thick BB plywood. I’m very happy with the cost and quality. There are limitations on sheet size, but if you are not building carcasses or whole workbench tops out of it, you should be able to order what you need.
Just an FYI, in case some folks are frustrated by local choices (as I often am).
These users thanked the author doncaparker for the post (total 6): Barry Daniels (Wed Jan 10, 2024 11:47 am) • kfish (Tue Jan 09, 2024 3:07 pm) • Kbore (Sat Jan 06, 2024 1:55 pm) • bcombs510 (Fri Jan 05, 2024 11:01 am) • Pat Foster (Fri Jan 05, 2024 9:26 am) • SteveSmith (Fri Jan 05, 2024 9:10 am)
Users browsing this forum: Bing [Bot] and 33 guests
