It is currently Fri Jul 18, 2025 3:01 am
PostPosted: Sat Jun 08, 2024 6:33 pm
First name: Karl
Last Name: Borum
Zip/Postal Code: 63303
Would you be so kind as to show your neck carving jig?
Mine, cobbled up from a pallet runner has split and is no longer useable.
I bought a nice 2" x 3 3/4" x 40" long black walnut cut-off for the new one.
I'm thinking a hinged headstock end may come in handy- thoughts?
Measure Twice,
Karl Borum
PostPosted: Sat Jun 08, 2024 7:31 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
Look at the third post down in this thread:
viewtopic.php?f=10101&t=55545&hilit=Total+vise
I cut a 15 degree slice off one side and glued it onto the other side, and cut a notch at the transition. The notch allows for the area where the headstock veneer sticks out a bit. The holes are for clamps to hold the neck in place. Cheap, and it works great.
These users thanked the author doncaparker for the post: Kbore (Sat Jun 08, 2024 8:30 pm)
PostPosted: Sat Jul 13, 2024 3:55 pm
First name: Karl
Last Name: Borum
Very nice, thank you.
Measure Twice,
Karl Borum
PostPosted: Sat Jul 13, 2024 5:08 pm
One of my kids built a Martin kit back in 1996 and Martin sold their neck carving supports back then and he bought one. I am still using it.
ImageIMG_7096 by Terence Kennedy, on Flickr
These users thanked the author Terence Kennedy for the post: Kbore (Sat Jul 13, 2024 11:15 pm)
PostPosted: Sun Jul 14, 2024 8:22 am
Here's mine, posted this some time a go, still using it.
http://www.luthiersforum.com/forum/viewtopic.php?f=10117&t=26349
These users thanked the author Colin North for the post: Kbore (Sun Jul 14, 2024 4:03 pm)
PostPosted: Sun Jul 14, 2024 12:40 pm
First name: Freeman
Last Name: Keller
Here is mine with a neck sitting in front.
I can move it around my workbench to gain access to various parts of the neck and turn it on its side if necessary. One thing I would do differently is make the head angle adjustable.
These users thanked the author Freeman for the post: Kbore (Sun Jul 14, 2024 4:03 pm)
PostPosted: Tue Jul 16, 2024 4:27 pm
Here is mine. I shape all my necks with my belt sander. It's amazing how fast the rough-in goes with some 36 grit. When I get close to the final shape I change to 60-80 grit. After this, I change to the wood rasp, flat sanding blocks, and various sizes of cardboard tubes, with sticky back sand paper. The round tubes are for finishing out the curved areas at the heel and the transition of the neck to the peg head. I have never carved one.
The belt sander also doubles as the shaper, for my bridge wings. Flip up the drum and us a block of plywood to get the wing thickness close, and then layers of wood veneer to tune it in. l also can use this setup to thickness the peg head.
These users thanked the author guitarjtb for the post (total 2): SteveCourtright (Wed Jul 17, 2024 5:16 pm) • Kbore (Tue Jul 16, 2024 5:57 pm)
