Where to source wide torrefied spruce sets 18" wide top?
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=57124
Author:  Octave [ Wed Jul 09, 2025 8:19 pm ]
Post subject:  Where to source wide torrefied spruce sets 18" wide top?
I'm gearing up to build a large acoustic baritone guitar, and I'd like it to have a wide lower bout (17"-18"). I'd also like to use torrefied Sitka Spruce, but I'm having trouble finding sets that are larger than 8 1/2" wide. I'd like to have at least an extra half inch on each board, so I'm looking for cuts of torrefied spruce that are a minimum of 9" wide, ideally 9.5"+. Does anybody know where I could find a top set of this size?
Author:  Brad Goodman [ Wed Jul 09, 2025 8:43 pm ]
Post subject:  Re: Where to source wide torrefied spruce sets 18" wide top?
Alaska Specialty woods.....
Author:  bobgramann [ Wed Jul 09, 2025 9:28 pm ]
Brent at Alaska Specialty advertises some torrified tops at 8.5” minimum. If you called or emailed him, he might consent to picking out some for you above the minimum. That said, taking the cutoffs from the upper bout and carefully matching the grain and runout and moving them down to the wings on the lower bout would make the joints there undetectable. I’ve done where I knew it was a 4 piece top but wondered later if it was.
Author:  Hesh [ Thu Jul 10, 2025 5:08 am ]
Welcome to the OLF Alex. Sounds like a great project you have.
Author:  rmmottola [ Thu Jul 10, 2025 4:35 pm ]
Yet another recommendation for Alaska Specialty here. Contact Brent and let him know your dimensional requirements. If the plates will be wider than conventional they will likely be longer than conventional too. The last oversized tops I got from him were intended for harp guitars, but worked well for my ABGs. Oh, and if it is possible to reconsider the torrified requirement, there may be more options available to you.
Author:  Alaska Splty Woods [ Fri Jul 25, 2025 4:15 pm ]
We have at least one LOL!
I just took a tape measure to the shelves. Most are at or just under 9" wide, But there are a few wider. The stack I looked at was the AAA NF sort.
Hit us up. brent@alaskawoods.com
