It is currently Wed Jul 23, 2025 5:55 pm
PostPosted: Tue Apr 05, 2005 7:09 am
Quick question, and I think I know the answer, but not sure. What is the difference between the fretboard radius and the top/back radius? Top/Back uses "feet" radius, so a 25 foot radius is basically a 25' diameter ball and a cut out section of the bottom of the ball. But a fretboard radius is in inches, is this correct? So a 12" radius is the same as a small cutout section of a 12" diameter ball? It just seems that the radius is much greater when you talk in inches, but a fretboard radius doesn't look that curved.
PostPosted: Tue Apr 05, 2005 7:14 am
Your correct -
PostPosted: Tue Apr 05, 2005 7:32 am
No, not correct.
Diameter = Radius x 2
So, a 12" diameter ball would have a 6" radius.
PostPosted: Tue Apr 05, 2005 7:33 am
NO! Wait...don't sand that fingerboard radius yet!
A 12 inch radius would be cut from a 24 inch diameter ball, or circle. A cut from a 12 inch diameter ball would give you a 6 inch radius. Radius is from the center of a circle to the perimeter, or 1/2 the diameter.
PostPosted: Tue Apr 05, 2005 7:42 am
Thanks Hank, so if that is true, then a guitar top that has a 25' radius would have been a radius from a 50' diameter ball?
Yep. The back and top are the surfaces of a sphere (or ball) with a pretty darn huge diameter (twice the radius), measured in feet, but the fingerboards are sections of a cylinder (single radius) or a cone (compound radius) measured in inches (and again, diameter = twice the radius). If you look at a fingerboard head-on, you can plainly see the curve over a span of less than 2". Look at a 2" wide piece of top or back, and I challenge you to see any curvature at all.Mattia Valente38447.6971643519
PostPosted: Tue Apr 05, 2005 7:48 am
Thanks for clearing that up Mattia. Makes sense!
PostPosted: Tue Apr 05, 2005 8:07 am
What Mattia said.
Tops and backs are HUGE radii items.
PostPosted: Tue Apr 05, 2005 8:41 am
Um - ya what he said!
Actually I've always thought it was part of a smaller ball - I stand corrected
PostPosted: Tue Apr 05, 2005 9:24 am
Lance, I think you are thinking about the smaller radius top that results when the drum player wraps an ovation around a heckler's neck. Or something like that.
PostPosted: Tue Apr 05, 2005 10:52 am
Last Name: Johnson
State: CO.
Zip/Postal Code: 80224
WAIT-it's a piece of pie X the radius of the plate squared.
PostPosted: Wed Apr 06, 2005 2:31 am
[QUOTE=bob J] WAIT-it's a piece of pie X the radius of the plate squared.[/QUOTE]
CAKE????
PostPosted: Wed Apr 06, 2005 3:15 am
Pudding...How can you have any pudding if you don't eat your meat.......pie R square.....Just another birick in the wall other wise known as the area a circle
PostPosted: Wed Apr 06, 2005 3:16 am
Not if you measure in cubic furlongs per fortnight!
