It is currently Sun Aug 17, 2025 4:09 am
PostPosted: Wed Nov 15, 2006 3:29 am
Well lately I have been asking a lot of FP questions because I am going to
try it for the 1st time. I plan on following Robbies video. My 1st guitar
(from a kit that never really got finished....crooked body) is the guinnea
pig.
With Zpoxy as the filler I am getting mixed info. Some say to sand back
to bare wood (obviously not to the point that you sand open the poors)
Some say leave a slight amount all over so you don't get dull spots.
I was going to add a 2nd coat that is thinned with Denatured alcohol. If I
sand back to wood, and then add this 2nd coat, wouldn't the light/dark
areas not be an issue. Also if you do add a thin 2nd coat, do you sand
that at all.
Finally, can you use an orbital sander to sand the Zpoxy back or are you
better off doing it by hand?
Thanks again
Andy
PostPosted: Wed Nov 15, 2006 3:37 am
Andy,
On a French polish application, for that mater all finishes I sand back to bare wood. leaving Zpoxy in the pores. On a sprayed finish I do the 60/40 mix wipe. On French polish I do not. However you could. If you don't be sure to get all the Zpoxy off the guitar surface so that the shellac will evenly color the woods.
on French polish I like the shellac to tint the woods However if you chose to do the 60/40 wipe down evenly dull it every where to give the shellac a tooth to adhere to. Some claim to have had an issue with shellac sticking to shinny Zpoxy. Personally I have not. but I do wipe down with DA prior to applying the shellac This softens the 60/40 mix a tad and I think helps the shellac adhere.MichaelP39036.486412037
PostPosted: Wed Nov 15, 2006 3:47 am
First name: Mark
Last Name: Tripp
City: Olympia
State: Washington
Zip/Postal Code: 98506
Andy:
I've only used Z-Poxy on the last two, so others probably have a better handle on it. I don't sand back to the wood. After the first coat, which I squeegee off VERY thin, I let it cure for at least 36 hours, sand back using 220 grit and a cork pad just enough to knock back any high spots, and lightly scuff all over. Rinse, repeat... Third coat, I thin out the epoxy about 30% with alcohol, and wipe on with a lint free rag. I let it cure and sand lightly with 320 grit, again knocking down any high spots. I wipe down with naptha so I can see better, then hit everything with 400 on a cork pad. Don't know if it's right, but it seems to be working well - the last two have the best finishes so far.
I don't think you need to use the sander, this stuff is easy to do by hand...
-Mark
Pullman, WA
trippguitars.com
OR
Find me on Facebook
PostPosted: Wed Nov 15, 2006 4:01 am
thanks
PostPosted: Wed Nov 15, 2006 4:07 am
I AGREE DO NOT USE A SANDER YOU WILL END UP OPENING PORES BEFORE YOU KNOW IT. SORRY FOR THE ALL CPS I AM IN AN APPLICATIONT THAT REQUIRES IT AND DID NOT WANT TO FORGET TO SET THEM BACKMichaelP39036.505625
PostPosted: Wed Nov 15, 2006 5:00 am
Andy,
I finished my last in FP. It was my first attempt at FP. I applied Zpoxy over the entire guitar and did not sand back to bare wood. Any FP mistakes only made it to the epoxy layer. This made it easy to repair without causing any uneven coloration in the wood.
Bruce
PostPosted: Wed Nov 15, 2006 5:24 am
Stupidity removed....
Don Williams39036.6088773148
...and more stupidity...Don Williams39036.6092476852
PostPosted: Wed Nov 15, 2006 5:38 am
Nope not from this topic anyway, but it did a little when I opened a box with your address on it last night
PostPosted: Wed Nov 15, 2006 6:06 am
I did as Mark stated on a recent FP experience. It worked well.
Good luck, Andy! I found my first attempt at FP to ultimately be satisfying and rewarding. I'm still nursing tendonitis in the elbow but only because I had to re-do a lot of rookie mistakes. My next attempt will go better...perhaps as a southpaw!
PostPosted: Wed Nov 15, 2006 6:37 am
[QUOTE=MichaelP] Nope not from this topic anyway, but it did a little when I opened a box with your address on it last night[/QUOTE]
Ouch...
