It is currently Sun Aug 17, 2025 1:17 pm
PostPosted: Wed Nov 29, 2006 3:57 am
What sort of respirator/filter will I need for applying toxic finishes?
I have the Northern Safety Co. catalog in front of me and its a little overwhelming.
-j.j.Brown39050.542974537
-jack handy
PostPosted: Wed Nov 29, 2006 5:21 am
First name: Tom
Last Name: Rein
City: Saline
How toxic? If you are spraying nitro, a charcoal type filter will protect your lungs, although you will be absorbing solvents through your skin to a small degree. If you are spraying a catalyzed finish, you need a supplied air respirator that pushes fresh air through a helmet/visor and a whole body suit. If you are spraying catalyzed finishes, I pray for your neighbors sake that you are in an industrial area, not your garage.
Stay with the happy people.
--Reynolds Large
PostPosted: Wed Nov 29, 2006 6:39 am
J. Contact your finish distributer and ask them to get you the Material Safety Data Sheet (MSDS) for the product you are using. On that sheet it will describe the hazards associated with the product and the precautions required to protect yourself, including what filters would be required for your respirator. If buying a new respirator, don't do it through a catelogue. These things need to be fit tested to you. If they leak, they are useless. You will need to be clean shaven to get the required seal on your face. Otherwise, it will be air supplied as Tom has suggested (does it show that I am in Occupational Health and Safety as a day job!).
Good luck in your choice.
PostPosted: Wed Nov 29, 2006 8:41 am
you want a filter canister which will handle volatile organic compounds, voc's in common parlance.
when spraying nitro i also wear a tyvek coverall suit and nitrile gloves. i don't want it on me or in me.crazymanmichael39050.697650463
PostPosted: Thu Nov 30, 2006 11:17 am
Shane is right. Make sure you get your respirator fit tested and learn how to do a positive and negative fit test each time you use it to insure everything is working properly. If you get one with a standard charcoal cartridge store it in a clean, zipped plastic bag. It will passively absorb chemicals and shorten its life span. My two cents from retired Occ Health guy.
Bob
PostPosted: Thu Nov 30, 2006 11:25 am
Another bit of advise is to date your cartridges. As Bob said, once open and exposed to the air they are working. You should replace your cartridge eery 6 months or when yuo get the faintest order passing through your respirator.
PostPosted: Fri Dec 01, 2006 12:04 pm
Thanks, guys.
-jack handy
PostPosted: Fri Dec 01, 2006 12:47 pm
Nitro sounds pretty interesting. How about a 1 line discription?
