It is currently Sun Aug 17, 2025 8:39 pm
PostPosted: Sun Dec 03, 2006 3:42 am
Last Name: Johnson
State: CO.
Zip/Postal Code: 80224
Does anyone know the scoop on this guit? The only diff. between OO and deep body is the deep B. is 1/2 " deeper. Is the bracing different than OO? This is the only style that I am aware of that has a 'deep body' model.
PostPosted: Sun Dec 03, 2006 7:00 am
don't know but suspect that the bracing is just typicl OO bracing with maybe some heaver side braces if anything.
PostPosted: Sun Dec 03, 2006 7:15 am
   Bracing has to do with scale length not body depth. Most "deep bodies" are usually dred depth. Other than that it is the same as the shallower bodies
john hall
PostPosted: Mon Dec 04, 2006 12:05 am
Last Name: Johnson
State: CO.
iF 2 GUIT. are built exactly the same except one os the'deep body. What will be the difference in sound between the two?
PostPosted: Mon Dec 04, 2006 5:25 am
Well assuming two guitars could actually be buit exactly the same I think it would haver more bass and loose some of the highs. This is based on my building one and comparing to my other 000 builds - of course I didnt use the same wood so who knows.
PostPosted: Mon Dec 04, 2006 9:50 am
The Gibson Nick Lucas Special is built that way. An L-00 with a deeper lower bout.
Chris Nielsen
Soquel, CA.
PostPosted: Tue Dec 05, 2006 7:26 am
Last Name: Johnson
State: CO.
But why did they do it for OO and not others. Do they feel that the OO needs more bass?
PostPosted: Tue Dec 05, 2006 8:10 am
I think Nick Lucas asked for it that way.
Chris Nielsen
Soquel, CA.
PostPosted: Fri Dec 08, 2006 8:32 am
Last Name: Johnson
State: CO.
Thank you all very much!
