It is currently Sun Aug 17, 2025 10:35 pm
Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2
PostPosted: Wed Dec 06, 2006 4:06 am
Wow, John, sounds just awesome! Love that woody old-timey tone!
PostPosted: Wed Dec 06, 2006 10:03 am
I'm gonna have to build me one of those! I doubt mine will sound as good tho
Sounds fantastic, great playing too!
PostPosted: Wed Dec 06, 2006 12:47 pm
John -- great sound, endorsed by a great player -- one heck of a builder..    Oh ya -- good guy too
PostPosted: Thu Dec 07, 2006 1:26 pm
John,
I'm not much of a blues fan, but your guitar sounds awesome! I've got a parlor that needs a new top and this has convinced me to try ladder bracing. If you don't mind, I may bug you for measurements and advice later this winter.
PostPosted: Thu Dec 07, 2006 7:43 pm
Very, very nice! got any shots of the bracing?
PostPosted: Fri Dec 08, 2006 12:55 am
[QUOTE=Mattia Valente] Very, very nice! got any shots of the bracing?[/QUOTE]
Pretty simple stuff really, The braces are 1/2' wide and 1/2' tall and tapered from full width to about 1/8" at the top. They are also tapered for the last 2 1/2" at the ends. The top is actually flat, which makes building this guy a little easier and more fun. Actually the original didn't have the popcycle brace but I thought it needed something there and I wanted to keep the weight to a minimum and so didn't want an extension block.
John How39059.3729050926
PostPosted: Fri Dec 08, 2006 12:57 am
Now that's cool!
PostPosted: Fri Dec 08, 2006 1:36 am
Thanks for the info, John. What is the bridge plate? Looks like spruce, but I'd imagine that the ball ends would really dig into that.
PostPosted: Fri Dec 08, 2006 3:38 am
Yes the bridge plate is spruce as were the old ones. I most times glue on a small hardwood patch in the area of the string balls. I have used carbon fiber for this as well as various hardwoods. My latest batch uses "Snakewood" for some additional "mojo".
PostPosted: Fri Dec 08, 2006 4:21 am
Thanks!
PostPosted: Fri Dec 08, 2006 4:32 am
I shouldn't really be telling you this. On my bridge plates, no matter what they're made of I add a small bone plate with holes in it for the ball ends of the strings to pull against. This does not need to be permanently fixed to the plate if you don't want but can simply be held in place by the strings. (Leave the centre strings on, until the new Es have been fitted, when changing strings).
Then, the string is then on a bone nut, bone saddle and bone 'bridge plate'. Try it and see the difference that it makes. If you don't like it simply take it out.
See this is the sort of high end stuff that you're probably not ready for.
PostPosted: Fri Dec 08, 2006 5:28 am
See what I told ya, Colin is a very wise man....or is it wise A.. uh, well you get it.
PostPosted: Sat Dec 09, 2006 10:35 am
Thanks for sharing your secret, Colin. I was hoping to find the trick that would catapult my guitars to world class status and avoid that whole tedious experience thing. BTW, is that little piece of bone scalloped or parabolic?
John, On a serious note, How thick do you make the spruce plate? It doesn't look very thick in the pic.
Thanks.
PostPosted: Sat Dec 09, 2006 12:12 pm
John thanks for the sample I ordered two of his cds they came yesterday they are both outstanding.
