It is currently Tue Aug 19, 2025 3:45 am
PostPosted: Thu Dec 14, 2006 5:31 am
Before I risk snapping some very expensive zoot I thought I'd ask.
I'm planning on bending Bob C's Snake-a-lam purflings and Snakewood bindings at the same time.
Any advice based on prior experience would be appreciated.
TIA
PostPosted: Thu Dec 14, 2006 5:58 am
First name: Josh
Last Name: French
City: Houston
Buy extra, keep CA glue handy, bend at a high heat, try to keep both sides reinforced, take them down to nearly final thickness first, and keep the tweezers handy.
Instagram: @jfrenchluthier
PostPosted: Thu Dec 14, 2006 6:43 am
What these guys said!
And as JF implies with his tweezer comment, you might want to invest in a nice pair of thin gloves. The slivers want to jump at you. It's insane. Last time I worked with it, Jenn and I had a little "pull all the slivers out of Paul's hands" party for about an hour.
PostPosted: Thu Dec 14, 2006 7:17 am
Thanks guys...just what I need to know...and prepare for Sounds like it's better that I have all the routing completed before even thinking about the bending operation.
PostPosted: Thu Dec 14, 2006 7:23 am
Good advice and don't try to bend them too thick. High heat but don't cook them too long, I scorched a set by leaving them hot too long.
best of luckJohn How39065.6424652778
PostPosted: Thu Dec 14, 2006 9:45 am
John...what's your opinion as to the upper limit on thickness...and temp?
I'm planning to SuperSoft the bindings. I've had very good results bending difficult sides...why not try it here.
PostPosted: Tue Dec 19, 2006 10:36 am
Update:
I successfully bent the bindings!
Here's what I did:
1) Taped 4 bindings in 4 places
2) Spritzed the SuperSoft 2 and let the bindings sit in aluminum foil for a day.
3) Next day, I spritzed with water, sealed in foil and placed in the Fox Bender
4) Heated to 325* and allowed to cool to RT
5) Heated again to 325* and allowed to cool
6) Taped bindings in the mold form until ready to use.
There was no springback and they look great. Incidentally...each time I've used the Super Soft 2 on difficult woods I've had success. I believe there's something happening and so far it's been good. I continue to recommend this stuff.
Thanks to those who offered advice.JJ Donohue39070.7838310185
PostPosted: Wed Dec 20, 2006 1:18 am
JJ where arte you buying your Supersoft?
PostPosted: Wed Dec 20, 2006 1:32 am
http://www.joewoodworker.com/catalog/product_info.php?produc ts_id=616
PostPosted: Wed Dec 20, 2006 1:43 am
Can't get that link to work. It keeps saying product not found.
-j.
-jack handy
PostPosted: Wed Dec 20, 2006 1:45 am
link
Gotta take out the extra space in "products" in the URL.
PostPosted: Wed Dec 20, 2006 1:48 am
I've heard of using a little fabric softener in with the water to help bend highly figured wood. I've never tried it though.
Anyone else hear this or try it?
PostPosted: Wed Dec 20, 2006 3:15 am
I guess it depends on what smell you want eh?
Thanks for the other tips Hesh.
PostPosted: Wed Dec 20, 2006 3:49 am
Now I got the link to work. Just put my order in.
-j.
-jack handy
PostPosted: Sat Dec 23, 2006 11:26 pm
Sorry to be late, but thanks for the great tips guys, i have some snakewood here too!
