It is currently Tue Aug 19, 2025 3:45 am
PostPosted: Thu Dec 28, 2006 12:12 am
HI Folks, I have a customer who wants his output jack from his pickup to be on the lower bout of the guitar, (Similar to where it's located on a Les Paul.) Not in the typical location of the end block. I had thought of doubling up the side just around the jack area, or put a mahogany block there. Or should I convience him to not do that and keep it in the treditonal location?
PostPosted: Thu Dec 28, 2006 12:13 am
I should mention, this is a small jumbo acoustic.
PostPosted: Thu Dec 28, 2006 12:44 am
I would put a mahogany block there.
PostPosted: Thu Dec 28, 2006 12:46 am
definitely put a block there or it will split the side or worse break out.
PostPosted: Thu Dec 28, 2006 12:54 am
i would strongly try to convince him to use the endpin location.
failing that the suggestion above to put in a block is very good. anything less and you run a very great risk of spliting the side somewhere along the line.
PostPosted: Thu Dec 28, 2006 2:10 am
better yet (over mahogany), a 1/2 inch thick piece of baltic birch ply, contoured to fit - I now use nothing else for end blocks.
