It is currently Tue Aug 19, 2025 10:09 am
PostPosted: Mon Jan 15, 2007 4:20 am
I am thinking of going to solid moulds for side bending but will still use them in my fox bender, since I have it built already! So I am wondering how many of you that use solid moulds use two blankets (one on top one on the bottom) for bending. If so, what temp do you run them and do you use seperate controls for each blanket or just gang them to one router speed control device. Any advise would be most welcome!
PostPosted: Mon Jan 15, 2007 4:54 am
Hey Shane, looks like you're gonna bend sides soon! Keep us posted!
PostPosted: Mon Jan 15, 2007 5:15 am
Shane, I just received my blanket from John Hall last week.
Years ago John Mayes wrote this for the 13th fret: 13thfret.com/articles/
sidebending.html
My blanket from John came with a temp. control and a thermometer. I
did some testing the night it came and found that if I put the dial right
between the green and red, it maxed at 303 degrees and got to 240 in
about 2 1/2 minutes.
In that article, John uses 2 blankets, but I just used 1. I haven't taken the
side out yet, but I'll report back to let you know about spring back.
PostPosted: Mon Jan 15, 2007 6:09 am
to control two heating blankets from one router speed controler you would have to opt for the 2.5 watt/sq. in. version. two 5 watt/sq blankets could overload the speed controler.
one blanket is sufficient. two requires that your forms be made to account for the extra thickness between the form and the wood, but will heat the wood that much faster, and burn it, and unfortunately, other things as well, that much quicker if you are inattentive.
PostPosted: Mon Jan 15, 2007 8:29 am
Shane, I don't use a solid form but I do use 2 blankets. I was down at John Mayes shop one day and he showed me his 2 blanket setup and I tried it out for myself. I haven't broken a side yet doing this and it seems like I have better luck "setting" the bend using 2 blankets.
I also use John Hall's method of wet craft paper on both sides of the wood. I've bent some pretty tough sides using both of these methods together.
Now, hurry up and start building something, we wanna see some pics.
PostPosted: Mon Jan 15, 2007 9:32 am
I really don't think it matters if you use one or two, as long as the wood gets to temperature. I've always been happy with one, I've only bent about 60 sides but never had a break. Used to use foil but now use brown craft paper. I believe it's getting a feel for the wood that matters most, that's why I don't use a bender with mechanical aids I like to bend the wood round the form by (gloved) hand and just hold it with the cauls.
PostPosted: Mon Jan 15, 2007 10:51 am
Shane, I use a solid form, and one blanket under the side. After spritzing
the side I wrap it in foil and stack it slat-blanket-side-slat. I set the
temp. control to about 75%. When I can here the water sizzle, I crank
down the waist, then each end. So far it's been foolproof!   Only once
have I had to cycle it twice (to elliminate springback), and that was with
Granidillo.
for me, the most important thing with Fox style benders is the spring
support under the waist.
long
PostPosted: Mon Jan 15, 2007 11:06 am
By the way, Shane... I installed a burl rosette today in the Lutz top you
sent me recently.    It is Beeee-utiful!!
longBob Long39097.7972337963
PostPosted: Mon Jan 15, 2007 11:23 am
Thanks for the comebacks! I have one blanket now so I think I will try Bob's method and go from there. I just really like the idea or full support over the entire side when shaping.
Bob, I will maintain all of the Fox bender atributes...just different moulds. Let's see that rosette!
Thanks again all!
PostPosted: Mon Jan 15, 2007 12:23 pm
two are not needed, but, in my experience, they are faster, more reliable,
and seem to set the bend much better. I've done dozens with one blanket
and around 500 with two blankets, and two blankets are superior imo.
PostPosted: Mon Jan 15, 2007 12:28 pm
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
Solid form covered with heat resistant duct tape and one blanket.can`t wait to get that Lutz top your sending.
                   James W B
James W Bolan
Nashville Tennessee
PostPosted: Mon Jan 15, 2007 12:53 pm
Shane, The server won't let me upload the image of the rosette. I guess
people were having trouble earlier today. I'll try again maybe tomorrow.
I'm not much of a propellerhead, but I have posted images here before,
so I hope it's not just me.
longBob Long39097.8741898148
PostPosted: Mon Jan 15, 2007 1:08 pm
The amount of blankets isn't as important as the wattage of the blankets. 4 and 5 watters will have the power to overcome the thermal shock
   lighter wattages will have a temp drop and it takes longer for them to come back to heat.
   The important thing is the recoup time for heating
john
PostPosted: Mon Jan 15, 2007 3:31 pm
Shane, as you know, i use one blanket and 3 bulbs, some people even bend with just the bulbs so the 2 combined methods will give you more than enough heat IMHO.
PostPosted: Tue Jan 16, 2007 3:43 am
Thanks again everyone!
Serge, I am going to solid forms so the bulbs won't work. I have done my first, including the cutaway, with just bulbs and it worked well but I really want to move to solid forms as I think that they will give a more defined bend (I had a small issue with the cutaway on the first that required a rebend, second time was fine).
PostPosted: Tue Jan 16, 2007 3:44 am
I use one blanket from John, it works very quickly and is easy to control--no problems.
