It is currently Sat Jul 26, 2025 1:44 am
PostPosted: Wed Apr 27, 2005 3:05 am
Your now the proud owner of a Build a Steel String Guitar with Robbie O'Brien DVD
Thanks John and Robbie!
Bid History:
Bidder: John Elshaw      Bid: $35.00
Bidder: Don Atwood      Bid: $28.00
Bidder: David Rector      Bid: $25.00
Bidder: David Bland      Bid: $10.00
PostPosted: Wed Apr 27, 2005 6:17 am
Wow, thank you! I guess I'm going to seriously have to consider building a steel string now. I have the classical dvd, and if the SS is as good, I should be able to pull it off. Thanks Lance/Robbie!
PostPosted: Wed Apr 27, 2005 10:13 am
Hey John, Congrats! When you get the DVD and watch it, can you do a comparision of the products and give a little review for us all?
Thanks!
PostPosted: Fri Apr 29, 2005 1:34 am
JOhn,
congrats and thank you!! You should have no problem building a steel string. With your classical back ground you should be able to make the transition very easily. I also would be interested in hearing what you have to say about the two dvd's.
good luck!
