It is currently Tue Aug 19, 2025 12:37 pm
PostPosted: Sat Dec 30, 2006 2:57 am
I have just transfered everything to a new computer and am wondeering how I transfer my firefox settings and bookmarks over.
PostPosted: Sat Dec 30, 2006 5:42 am
Richard,
Do you have a Mac or PC?
PostPosted: Sat Dec 30, 2006 6:00 am
Last Name: Johnson
State: CO.
Zip/Postal Code: 80224
I think it's right in the setup portion of installation
PostPosted: Sat Dec 30, 2006 1:19 pm
Rich, check out this link: transferring Firefox profiles
Hesh is right, you'll need to use some sort of removeable media to do this. The file that you need to transfer isn't that big, so it shouldn't be a problem.
PostPosted: Sat Dec 30, 2006 3:18 pm
Yes I am trying to move Fire fox Bookmarks to a new computer. They are both running windows XP and are networked so moving data from one to the other is no problem. I followed the instructions above but had no luck. What I really need to do is find the File that contains the bookmarks on my old computer and then move it to the new computer. I just have no idea what this file is called and moving the contents of the profile folder to my new computer doesn't seem to do it.
PostPosted: Mon Jan 01, 2007 12:20 pm
Bookmarks menu -> Organize bookmarks
in the new window that pops up: File -> Export...
It'll save it as an html file.
Transfer it over to the other computer and start up firefox there
Bookmarks Menu -> Organize Bookmarks
File -> Import
Find the file and go!
I don't know how to export all of your settings though, only your
bookmarks.
PostPosted: Mon Jan 01, 2007 2:47 pm
Richard, try this link.
It has been awhile since I did this and I cannot find the same exact website I used which had much better directions. However, this is basically what I did at the time.
PostPosted: Tue Jan 02, 2007 4:52 pm
Thank you Jocafa, that worked things like this are so simple when you know how.
PostPosted: Sat Jan 20, 2007 6:21 am
for all you guys on the dark side this may be of no help. If you are transferring safari settings it is in the setup menu when you install firefox to your applications folder,takes about 30 secs and its all there.
