It is currently Mon Aug 25, 2025 12:10 am
PostPosted: Fri Jun 15, 2007 10:18 am
First name: Jim
Last Name: Kirby
I'm fretting my first classical with a split 19th fret as we speak, and I'm curious to see how people dress the soundhole ends of the frets. I don't have an example here to go by. If you have any pictures handy, I'd appreciate it.
Jim Kirby
kirby@udel.edu
PostPosted: Fri Jun 15, 2007 3:10 pm
Don't have a clue, Jim, but I will give you a bump.
PostPosted: Sat Jun 16, 2007 9:51 am
First name: Gary
Last Name: Lee
   After I have the fingerboard glued to the body, I press the half-frets into the FB with a clamp with a bit overhanging the FB's soundhole edge. Then I nip the ends close to the FB edge with the fretwire cutter. To dress the fret ends, I start with a small file and work it roughly flush to the FB edge and start to introduce a rounded bevel. Then I use various grits of sandpaper on a large dowel to finish the bevel and get the fret ends perfectly smooth with the fingerboard. The fret wire is soft enough that the sandpaper can take it down with no problem.
