It is currently Sun May 25, 2025 1:45 pm
PostPosted: Mon Aug 20, 2007 10:25 am
Last Name: Sterling
City: Ulster Park
State: New York
Zip/Postal Code: 12487
 I just bought a used Delta 18" sander. What grades of sand paper are commonly used for thicknessing tops, backs and sides? I don't want to invest in grades I won't use as it is pretty expensive. Any good sources of 2" wide sand paper to fit this thing? Thanks in advance for you help to a Newbee.
Mistakes are mandatory-learning from them is optional. http://www.opensourceluthiersupply.com
PostPosted: Mon Aug 20, 2007 10:52 am
and welcome too, green man. Smile
I use 80 grit but whadaIknow?
PostPosted: Mon Aug 20, 2007 1:40 pm
Last Name: Lloyd
Welcome.
I use 60 for bringing the harder woods to size then when they're within 1.5 mm of the desired thickness, I'll move to a higher grade like 120. I will sometime step up to 120 with 80 in between.
For the softer woods I will start with 80 and work up at times to 220.
I've also use 220 on harder wood with no problems.
I have found going slow and in small thickness increments wins the race with very little clogging of the sandpaper.
By the way, I have the same machine and I love it. It's a workhorse if treated well.
Michael Lloyd
PostPosted: Mon Aug 20, 2007 2:01 pm
I use 100 for everything except oily woods and they are done with 60.
My source for great paper.
PostPosted: Mon Aug 20, 2007 3:18 pm
I don't have a thickness sander, but Welcome anyway!
PostPosted: Tue Aug 21, 2007 1:08 am
You will use 120 the most but I also suggest you have 60 and 80 available for major removals.
I am lazy. I have Jet 10-20 and a Performax 16-32 amd I buy the pre packaeged ready to rap stuff.
PostPosted: Tue Aug 21, 2007 5:25 am
First name: Rick
Last Name: Hubka
City: Chemainus
State: BC
Zip/Postal Code: V0R 1K1
On my Performax 16-32 I use:
80, 120, 220 and 320 cloth rolls.
I get them all quite cheap from
http://www.supergrit.com
Rick
Rick Hubka
Chemainus BC Canada
