It is currently Mon Jul 28, 2025 2:09 am
PostPosted: Thu Aug 18, 2005 8:32 am
I am about to embark on my first guitar building project(I have chosen a “serviced kit” from ILM, based on the Martin D-28, to learn from.) and I am starting to build my jigs and fixtures for it. Two of which will be the sanding dishes. Does anyone know what the top and bottom radii are for the Martin D-28?
PostPosted: Thu Aug 18, 2005 8:56 am
The top is 28' and the bottom is 20'.
PostPosted: Thu Aug 18, 2005 9:58 am
Thank you!
PostPosted: Fri Aug 19, 2005 1:41 am
Yep Martin backs are a bit on the flat side. Till this May I built to Martin spec's on OOO,OM and dreads, but now I use 18' radius on Dereads, 15' on OOO and OM's
PostPosted: Fri Aug 19, 2005 2:38 am
Welcome to the OLF Howard!
Starting with a Kit is a great idea - My first was a D-18 kit, it allows you to seriously get your feet wet and end up with a pretty nice guitar when your done. If your like most (and I'm guessing you are) You'll be ordering wood for #2 before #1 is half done
Best wishes
Lance
