It is currently Sun Aug 03, 2025 11:48 am
PostPosted: Mon Jan 09, 2006 5:46 am
Anybody got one thses puppies that they no longer want/need? I think I might be interested.
PostPosted: Mon Jan 09, 2006 8:43 am
Cancel this, just ordered a Peterson 490.
PostPosted: Mon Jan 09, 2006 12:13 pm
   Shane, that's some serious tuner!
PostPosted: Mon Jan 09, 2006 1:08 pm
Ya, when I was talking with Siminoff I thought myself into it. Roger talked about the signal delay in the digital ones and indicated that they repeat every second which makes getting a tape on a sound board difficult. Where the analog ones are instantaneous and give you better results. So, I just thought why by something when I will just want upgrade later anyways.....goofy!
PostPosted: Mon Jan 09, 2006 2:01 pm
I think Roger must be thinking about some older digital tuners. The
Peterson Virtual strobes are real time with no delay. What they can't do
however is show any hint of harmonics and overtones. They only read the
fundamental.
Have you looked in to the Peterson Strobosoft program? I believe the full
version includes a spectrum analyzer and oscilliscope. I've never seen a
strobe tuner as having much use in tuning a soundboard. The whole idea
of strobe tuners is to view the motion of the disc pattern if the pitch
varies from correct. In the case of tapping a top or a banjo head, the tone
is so short lived that you could never really see if the pattern is stable or
in motion.
Seems like it may briefly appear and disappear at best.
For tuning anything with such rapid decay I find it hard to beat a tuning
fork or a string (or the pitch generator on the VSAM). If you wanted to
measure with more precision including overtones you should look in to
an audio spectrum analyzer program. Many of these allow you to record
peak frequencies, show real time or plot charts for things like decay.
PostPosted: Mon Jan 09, 2006 6:55 pm
Ahhhhh! See now I have a bunch more research to do! I have to defer to your better judgement David, I know tha you have published on this stuff. The tuner is on its way so I will be giving it a try and if it don't work for tuning plates then I gues I have an expensive but accurate tuner for setting up intonation and the like. Once I get it and start to use it and research a bit more, I am positive I will looking for a bunch of good advise! Like has often been said here, the more I know the more I know I don't know....but ya gotta start somewhere.
So thanks!
