It is currently Mon Aug 04, 2025 7:54 am
PostPosted: Fri Jan 27, 2006 6:02 am
[QUOTE=Hesh1956] This saw also has a tension lever that doubles as a toilet paper roll holder....[/QUOTE]
As always Hesh, we need some pictures. Very inovative.
PostPosted: Fri Jan 27, 2006 6:22 am
Did we ever get to see the Master Bathroom Workshop? If so I missed that thread.
PostPosted: Fri Jan 27, 2006 6:28 am
Congratulations, we are happy for ya man!
PostPosted: Fri Jan 27, 2006 11:20 am
[QUOTE=Hesh1956] The saw is white so it matches the room well......[/QUOTE]
AND - the man has a sense of decor!
PostPosted: Fri Jan 27, 2006 12:28 pm
Congrats on the new b-saw Hesh! I've been looking into 14" bandsaws lately.I'm real tired of my minature Delta. I'm leaning towards a Rigid.
PostPosted: Fri Jan 27, 2006 4:53 pm
I missed the pix too, what was the thread title? Hopefully obvious....I'll check
PostPosted: Fri Jan 27, 2006 7:06 pm
I recently picked up a broken 14" Harbor Freight special from 1987 for $50. After repairs and a riser kit I'm in for about $150. During the search for parts I found that many parts are interchangeable with other Taiwanese saws.
I think if I was buying a new saw it would be the Grizzly Go555 or their new 14" rip saw that handles wide stock with no riser. They have a little more power and come with roller bearing guides which are expensive to add later.
If you want a cheaper saw just get the HF and adjust it properly. I had to shim the arm to body connection to get the wheels in the same plane.
Kurt
PostPosted: Sat Jan 28, 2006 3:04 am
hesh, just let's not have any pictures of the jet whilst in use for its secondary function!!!
PostPosted: Sat Jan 28, 2006 4:45 am
Hesh you have actually influenced me in reverse, I want to install a toilet in my shop, I do a lot of "while you wait" repairs, do you think it would freak out the customers
Evan
PostPosted: Sat Jan 28, 2006 2:29 pm
Hesh, i know it's an easy one but when i'm thinking about your workspace and the toilet paper hangin' from the tensioning lever, what comes to mind is "pooh yew" !
PostPosted: Sat Jan 28, 2006 2:44 pm
Hesh, check out what i wrote in the other thread about bridges and geniuses at Harvard, you definitely fit in my description of a genius friend
