It is currently Sun Aug 03, 2025 10:43 pm
PostPosted: Sun Jan 29, 2006 5:13 am
City: Duluth
State: MN
I know that some of you guys with bending blankets will tape your bindings to the edge of the side to be bent, and bend the whole shootin' match at the same time. I'm concerned that the heat and pressure may drive the tape's mastic deep into the wood pores, and make a mess that even scraping may not fix.
What kind of tape do you use, if you're taping bindings to the edge of the sides for bending?
Dennis
Dennis Leahy
Duluth, MN, USA
7th Sense Multimedia
PostPosted: Sun Jan 29, 2006 5:21 am
Dennis, I just use regular ol' masking tape.
PostPosted: Sun Jan 29, 2006 5:46 am
Blue masking tape.
PostPosted: Sun Jan 29, 2006 6:00 am
I have used the blue, green, plain white, and even the brown binding type. Little sanding/scraping has always worked.
PostPosted: Sun Jan 29, 2006 6:05 am
I mostly use the brown tape. I sometimes use the 3M or Scotch Tape that is impervious to CA.
PostPosted: Sun Jan 29, 2006 6:21 am
City: Duluth
State: MN
Thanks, guys! Wish me luck on bending a set of waterfall Bubinga today (with a side plate of Katalox bindings.)
Dennis
Dennis Leahy
Duluth, MN, USA
PostPosted: Sun Jan 29, 2006 8:40 pm
I tape the pieces together tightly & tape them to the side with any old masking tape that's handy.
After ruining a nice set of figured maple bindings... I wrap the bindings in foil seperately, to prevent colour bleeding from one wood into the other.
No reason not to get your side purflings into the act at the same time.
And... make sure you remove all the tape residue soon after bending. If it sits around for a while it gets very difficult to remove.
Holy Smoke! I just noticed I made it to "senior member"...
I think you guys had better raise your standards. Daniel M38747.1973032407
PostPosted: Sun Jan 29, 2006 11:04 pm
Ah don't worry about it Daniel, i know what you're feeling!
