It is currently Mon Aug 04, 2025 2:55 pm
PostPosted: Wed Mar 01, 2006 8:26 am
I just received two beautiful rosettes from LMI and they have what can best be called, a wrinkle in them. Will this smooth out when I apply glue and clamp pressure? Should I spritz them now with a little water and lightly weight them as you do with wrinkled veneer?
Any help would be appreciated.
Regards, Steve
PostPosted: Wed Mar 01, 2006 8:33 am
set it on concrete over night,
PostPosted: Wed Mar 01, 2006 8:36 am
Steve,
Do you mean like a potato chip? If so, just some weight will do it. But if you are talking a ripple in the lines, then you could heat it with an iron(not too high of a temp)then press it out and add weight. If you get the temp too high, it could melt the glue and it could fall apart. Be careful.
PostPosted: Wed Mar 01, 2006 8:38 am
Michael,
Thanks and I will try it but this wrinkle is within the cross section, not side to side. I'll let you know tomorrow.
PostPosted: Wed Mar 01, 2006 8:39 am
Tracy,
Ripple across the lines.
I'm going to put it in my humid room on the concrete floor and let it stabilize before I do anything drastic.
Thanks, Stevesfbrown38777.6946875
PostPosted: Wed Mar 01, 2006 8:45 am
I would try placing it between two flat surfaces with a weight on top.
PostPosted: Wed Mar 01, 2006 9:01 am
John is probably right, I was thinking cupped the concrete my not help
PostPosted: Wed Mar 01, 2006 10:49 am
as a little followup, I called LMI. I probably should have done that at the beginning! Well, A very nice lady explained to me that the rosettes aren't as brittle as they seem at first and she encouraged me to lay it on a flat surface and push it flat. Well, I did and it went flat with a little effort but not undue effort. She said that working them in was not uncommon. I think I will put them under weight tonight and check results in the morning.
Thanks for the input!
