It is currently Mon Aug 04, 2025 2:55 pm
PostPosted: Sat Mar 04, 2006 3:22 pm
There was a discussion some time ago about making GO-Bars from fiberglass driveway reflector rods from home depot or lowes.
I just picked up some Orange reflector sticks $1.99 ea. 48" long. These are just too thick 5/16" diameter. I believe that the lolly pop reflectors (white 48" long) have fiberglass shafts that are closer to 3/16 diamter shafts.
Looks like I'll be going to lowes for an exchange tomorrow. I hope this helps anyone in a similar position as myself...building my 1st go-deck.
Of course, the orange thicker diameter rods could be used if they were kept longer than 24" or 23". Additionally, I found that bolt thread protectors (rubber) look like they would make great caps for these fiberglass rods since they are rather thick.
Hope this helps,
JP
PostPosted: Sun Mar 05, 2006 6:50 am
I am the one that post that I bought some orange ones from Lowes. The ones I bought were 3/16" dia. 5/16 would be way to thick at 24" but if you had a 48" tall go-bar deck y9ou could get away with them. i do use the 3/16" that come in the driveway markers. I buy them at the local Home Depot. They are just short of 48" so I adjust mt deck height to use 23" bars. MichaelP38782.5322800926
PostPosted: Sun Mar 05, 2006 7:00 am
   be careful when cutting this stuff. use a mask and if you don't have a fine blade use tape to help avoid fraying
john hall
blues creek gutiars
PostPosted: Sun Mar 05, 2006 7:35 am
I use the 48" long ones. I use a cafe'table of my workbench for the bottom, and I use a 24' X 24" peice of mdf on the (7.5')ceiling. No "frame" needs to be built. Works great! DOn't have much to store, except the bars.
PostPosted: Mon Mar 06, 2006 4:44 am
Don't use your bandsaw to cut these...the FG eats blades. Don't ask me how I know.
PostPosted: Mon Mar 06, 2006 4:45 am
Not as bad as you may think.
PostPosted: Tue Mar 07, 2006 8:45 am
First name: Mark
Last Name: Tripp
City: Olympia
State: Washington
Zip/Postal Code: 98506
Ditto on what JJ said - trashed a nice timberwolf blade doing this...
-Mark
Pullman, WA
trippguitars.com
OR
Find me on Facebook
PostPosted: Tue Mar 07, 2006 8:50 am
A cheapy circular saw (handheld, even) or jigsaw will cut through a bunch of these (say, a bundle of 10, tape them in the area you're planning on cutting using masking tape) in short order. The dust is nasty, though.
PostPosted: Tue Mar 07, 2006 8:58 am
If you get your fiberglass rods from Into the Wind (which works out to about the same price as Lowes, except you have to wait for shipping), they sell a nice little Zona hacksaw with blades that are good for cutting through the fiberglass rod (and carbon fiber).
PostPosted: Tue Mar 07, 2006 2:17 pm
All good cutting methods...I prefer the dremel with a fiber reinforced abrasion cuttoff wheel. This way I can add a chamfer to the cut edge quickly.
Just be sure to use a mask with this stuff...its way nasty and not worth the lung damage.
But ya just can't beat the low cost out of these sticks...$26 gets ya 24 rods and small and large rubber capped ends...
I found that the wire shelving caps come in a large and small sizes. A mix bag of both cost 1.97 usd. The small rubber cap fits the rod well and then the larger cap slips over the small one...I'm thinking this will help add some stability on the brace end...while some carpet keeps the opposite end of the rod stable in the go-deck.
Thanks for the replys..
JP
