It is currently Sun Aug 10, 2025 6:43 pm
Post new topic Reply to topic  [ 40 posts ]  Go to page Previous  1, 2
PostPosted: Mon May 01, 2006 3:27 am
First name: Scott
Last Name: Thompson
[QUOTE=Bruce Dickey] Ron, Ronn, John, and Don, you got it, a binding or purfling ledge cutting tool, the luthier had a machinist make for him. Tub-o-lard all around boys!
So who was the luthier?
Scott Thompson
Port Townsend,WA
-Billy Bragg
PostPosted: Mon May 01, 2006 3:30 am
Bruce, who's is it? I knew a guy in Sacramento that had one built but I haven't ever seen it.
PostPosted: Mon May 01, 2006 3:38 am
Funny, i was sure it was a French tool for mechanics that they call a "riggine de culbutage frotting on a goupille de jonction" around here! Whew, was i wrong!
PostPosted: Mon May 01, 2006 4:25 am
Is it a binding or purfling ledge cutting tool??
Oh..sorry...should have read the whole thread before posting
PostPosted: Mon May 01, 2006 1:10 pm
No Biggie Larry, Hey, this is Nelson Palen's concoction.
PostPosted: Mon May 01, 2006 5:22 pm
I shall call it "Nigel" I think.
PostPosted: Mon May 01, 2006 5:57 pm
It's HUGE! That must be some big purfling!
PostPosted: Tue May 02, 2006 12:14 am
Sorry, didn't make it clear enough. I was only funnin'.......didn't have a clue beyond it was a tool for cutting channels of some sort. Is it adjustable?
PostPosted: Tue May 02, 2006 12:24 am
What ever it realy is (Bruce and others have let the cat out of the bag, binding cutter) It's more fun making it up.    I've had some good laughs this morning.
PostPosted: Tue May 02, 2006 6:42 am
First name: Nelson
Last Name: Palen
I built this several years ago and, yes, it's for the binding and purflin rabbets. The cutter is an off-the-shelf 3-wing slot cutter. I have a set of rub collars for my standard binding and a set for the purflin. The cutter is just under 2" diameter which seems to minimize any tendency for tearout.
The guitar body mounts on a turntable and the router mounts in the end of an articulated arm.
cutter
I use the #308 cutter.   I find MLCS to be an excellent supplier of router bits with no shipping charge.
Nelson
P.S.   Glad you see you guys having so much fun with this.
PostPosted: Tue May 02, 2006 7:08 am
First name: Nelson
Last Name: Palen
Here's a "less large" shot of it in action. I replaced the UHMW pilots with aluminum later on.
PostPosted: Tue May 02, 2006 1:08 pm
I wish I was part machinist....
PostPosted: Tue May 02, 2006 2:50 pm
Nice Nelson. I can sure see where a 2" blade would provide a better cut. What do you have it attached too?
PostPosted: Wed May 03, 2006 1:59 am
First name: Nelson
Last Name: Palen
Don--I made an arbor to fit the 1/2" router collet. The arbor has diameters machined to fit the bearings as well as the cutter hole and threaded on the end for the 5/16" nut.
Bruce--The left side of my brain is machinist. The right side is luthier wannabee.
Nelson
PostPosted: Wed May 03, 2006 9:06 am
Nelson, being an old school teacher, and having seen your work, I believe your brain is ambidextrious.
Oh, and you are one of those rare people that can be anything they wannabe! And if you aren't already a luthier, there is NO hope for the rest of us.
Thanks for sharing this cooltool from your hand/mind and MCLS.
