It is currently Tue Aug 12, 2025 1:32 am
PostPosted: Fri Jun 02, 2006 12:47 pm
I am a dufus. I bought a balance on ebay ... I should have looked at the pictures more carefully. It is in perfect working order, but it is in ounces rather than grams. Before I put this back up on ebay I was curious to see if anyone was interested in it. I will sell it for $50.
(Yes, I know you can do the conversion but I would just rather have it measure in grams -- I found another one cheap on ebay.)
PostPosted: Fri Jun 02, 2006 1:35 pm
You dont want to be caught with one of those in your house here in Philly.
PostPosted: Fri Jun 02, 2006 1:53 pm
I am sure... but then when they see the big stash of wood with density numbers scribbled all over it they will just shake their head and move on.
PostPosted: Fri Jun 02, 2006 2:52 pm
Brock,
I have looked for one on ebay, but since I know little about them, can't tell which one is junk and which one is a good deal. What did you get?
Jeff
PostPosted: Fri Jun 02, 2006 3:56 pm
the Ohaus's are pretty good. In truth anything decent will work for our applications.
PostPosted: Fri Jun 02, 2006 4:13 pm
You know you could just plot ounces vs grams in an excel graph, print and laminate the graph, and keep it near the balance. That way you just need to refer to the graph and not have to convert every time you weigh something.
PostPosted: Fri Jun 02, 2006 11:31 pm
Yes, I thought about that, but the stops are put in place for ounces, so the gram calculations from stop to stop will be odd numbers (not the normal 1, 10, 100, 200 etc.)
These are cheap enough and plentiful enough just to get a metric one.
I guess I will put it back on ebay. I am sure I will get what I paid for it.
PostPosted: Sat Jun 03, 2006 5:08 am
Ouch, guys! From what I've heard, those Ohaus triple beams are the industry standard. $50 is cheap, and if I had 50 bucks I sure would have bought it. Drat!
PostPosted: Sun Jun 04, 2006 9:41 pm
Last Name: Bordeaux
City: Massena
State: New York
Zip/Postal Code: 13662
Brock,
I'll take it off your hands! E bay can be a pain
pm me with instructions.
Paul
Paul Bordeaux
http://www.bordeauxinlay.com
