| Official Luthiers Forum! http://w-ww.luthiersforum.com/forum/ |
| Lacquer Finish Question http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=10490 |
| Author: | slackkeymike [ Sun Jan 21, 2007 7:52 am ] |
| Post subject: | |
I tried to find my old posts (threads on this)...sorry for yet another thread on this subject. I have the top of my repair guitar fully sanded to wood, dings filled in with lacquer and 2-3 sanding coats applied. Its time for the finish layers. The question is how many, and do I have to sand between (actually, should I sand) between layers. Once final layer is down, I planned to start with 400 grit, then 600, then move on to micro-mesh. I have some of that auto polish/compound stuff I have heard about in here. I was planning on using a polishing arbor with that. Anybody want to correct/modify the recipe? Help is appreciated. Mike |
| Author: | JJ Donohue [ Sun Jan 21, 2007 8:03 am ] |
| Post subject: | |
I shoot 4-6 coats...each about an hour apart. Then let it cure for two weeks. Level sand to about 400 grit and shoot 4-6 more coats. Let cure for two weeks and then wet sand as youy described. It really helps to let the lacquer cure out sufficirntly before sanding. |
| Author: | Homeboy [ Sun Jan 21, 2007 11:11 am ] |
| Post subject: | |
JJ, why do you cure between the coats for so long? Every recipe I have seen or tried only cured the lacquer before the wet sand /buff operation. I would think you could spray 4-6 coats of lacquer, wait overnoght or a day or so, and then level sand with 400. Then spray 4-6 more coats and sit for 2 weeks then wetsand and buff. Blake |
| Author: | JJ Donohue [ Sun Jan 21, 2007 11:20 am ] |
| Post subject: | |
I only wait an hour between coats. I wait 2 weeks while it cures before sanding. There are 2 sanding sessions...one for leveling before applying the next 4-6 coats and the final wet sand & buff. My experience is that it sands much more efficiently the longer it cures. It will shine up to a greater sheen the longer you wait for final sanding. Hard, cured lacquer sands much better than partially cured (softer) lacquer. It takes patience but I believe it's worth the wait. |
| Author: | slackkeymike [ Sun Jan 21, 2007 2:06 pm ] |
| Post subject: | |
Thanks! Great recipe JJ. For the final buff (after wet sand/micro mesh) can someone suggest a polish recipe? Mike |
