| Official Luthiers Forum! http://w-ww.luthiersforum.com/forum/ |
| 1/3 hp motor, what to do with it? http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=10538 |
| Author: | John Elshaw [ Wed Jan 24, 2007 2:15 pm ] |
| Post subject: | |
I have a 1/3 hp motor I took out of my old benchtop drillpress I no longer use. Does anybody have any good project ideas I could use this motor for? I considered a buffing wheel or a radius sanding dish, but I'm not sure if the motor will be big enough? Any comments or other ideas? Thanks! John |
| Author: | Anthony Z [ Wed Jan 24, 2007 2:21 pm ] |
| Post subject: | |
John I power my homebrew buffer with a 1/3 hp 1750 TEFC Baldor motor. It has plenty of power. |
| Author: | crazymanmichael [ Wed Jan 24, 2007 2:23 pm ] |
| Post subject: | |
buffer yes, radius sanding dish no!!! not enough torque. |
| Author: | Jocafa [ Wed Jan 24, 2007 3:38 pm ] |
| Post subject: | |
Use it to power an old watchmaker's lathe. |
| Author: | Louis Freilicher [ Wed Jan 24, 2007 3:48 pm ] |
| Post subject: | |
[QUOTE=Jocafa] Use it to power an old watchmaker's lathe.[/QUOTE] Now your talking!! Just got myself a South Bend
| Author: | Serge Poirier [ Wed Jan 24, 2007 3:49 pm ] |
| Post subject: | |
I built my buffer with a 1/3 hp and would certainly make myself a ssmall sanding disc for rosette tiles with another one if i'm lucky enough to scrounge another!
| Author: | Jocafa [ Wed Jan 24, 2007 3:57 pm ] |
| Post subject: | |
I'd love to get my hands on a boley, but i'm broke at the moment :T I've been toying around with the idea of making my own. I've read through Dave Gingery's books; I just don't know if I'm handy enough to do it. (sorry, I don't mean to hijack the thread) If all else fails, you can probably get a fair sum for it on eBay or from one of us here ;) |
| Author: | JohnAbercrombie [ Wed Jan 24, 2007 6:02 pm ] |
| Post subject: | |
I had a combo sander with a disk and a 1x42 belt in one unit. A spare motor allowed me to separate the two functions- now 2 machines- so that I could have enough working room around each. Another junk motor got mounted on end and now is a 3" drum sander. Just put that motor under your bench and you will find a use for it in a few months. BTW, I don't know what folks are doing with their radius sanders, but once your 1/3 hp motor is geared down to 50 rpm or so, I think it should have enough torque for most sanding jobs. Cheers John |
| Author: | KiwiCraig [ Wed Jan 24, 2007 7:57 pm ] |
| Post subject: | |
Bingo ! John . I've been thinking of that drum sander idea. How do you attach the drum ? I have a 1400 R.P.M. motor. Cheers Craig |
| Author: | TonyKarol [ Thu Jan 25, 2007 12:24 am ] |
| Post subject: | |
I run my 12 inch buffer with a 1725 1/5 hp - great - will stall if I press too hard. Good for students, no burn thrus !!!! |
| Author: | JohnAbercrombie [ Thu Jan 25, 2007 5:13 am ] |
| Post subject: | |
Craig- Some of the 3-inch drums come ready to bolt on to a half-inch shaft, and that's what I used. http://www.leevalley.com/wood/page.aspx?c=1&p=20200&cat=1,42 500,42501 I actually used the motor from an oil burner (furnace) which had a flange-type mounting- ideal for a vertical installation. You can also make a mini-thickness sander by arranging a pivoting table/fence. It's good for messing with bindings, saddles, and bridge shaping. It helps to have a garage for all your home-built tools(!). Cheers John |
| Author: | charliewood [ Thu Jan 25, 2007 7:14 am ] |
| Post subject: | |
I saw an article online where someone is building thier own Veritas power sharpening system with such a motor, geared down to 900 - 1200rpm I believe is what the eventual adj speed of the laps. Anyhoo, Id love to build something like that, sure cant afford the $500+ they want for thiers. Cheers Charliewood |
