Rosette stain... http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=10840 |
Author: | Dave Anderson [ Fri Feb 09, 2007 12:50 pm ] |
Post subject: | |
Hey guys, I sprayed the first coat of lacquer and this yellowish stain appeared.I glued the rosette in with tightbond and brushed shellac in the channel.Any ideas' what it is and will it sand out? ![]() |
Author: | Dave Anderson [ Fri Feb 09, 2007 1:32 pm ] |
Post subject: | |
Thanks Hesh, Yeah I heard that Ca would do this.But I used titebond so I hope it does sands out. |
Author: | peterm [ Fri Feb 09, 2007 5:34 pm ] |
Post subject: | |
Dave, to me it looks like the purfling bled for some reason. Did you apply the shellac after the rosette was done or before? Try scraping with a razor blade and see if its removing any part of the stain. If in fact bled, then appliyng an epoxie on the top will not hide the stain (don't ask how I know) Best suggestion: black top like Hesh's Tiger myrtle guitar! ![]() |
Author: | Andy Zimmerman [ Fri Feb 09, 2007 5:47 pm ] |
Post subject: | |
CA will definitely do this. I had it happen on a guitar even with a vinyl sealer on i. |
Author: | LanceK [ Fri Feb 09, 2007 11:50 pm ] |
Post subject: | |
Dave, if this appeared - after - you applied finish, I suspect that it may be some residual glue on the surface that didn't get sanded off and the lacquer is allowing it to show, or darken different than the wood around it. I would follow the above advise and at least try to sand it back a little. |
Author: | Dave Anderson [ Sat Feb 10, 2007 12:07 am ] |
Post subject: | |
Thanks a lot guys. I brushed the shellac on the channel very well I thought so thats why I was surprised this showed up. I'll sand it back and start again. |
Author: | LarryH [ Sun Feb 11, 2007 2:14 am ] |
Post subject: | |
Dave, I'm curious - did you get that stain out? And did you figure out its origin? |
Author: | Dave Anderson [ Sun Feb 11, 2007 2:28 am ] |
Post subject: | |
Yeah, It came out with some sanding. I don't know how it happened but it's gone now! I'll be even more careful with the next rosette glue-up .Thanks fer asking Larry. |
Author: | Serge Poirier [ Sun Feb 11, 2007 2:42 am ] |
Post subject: | |
Good job Dave, happy it turned out well for ya! |
Author: | LarryH [ Sun Feb 11, 2007 3:30 am ] |
Post subject: | |
[QUOTE=DaveAndy] Yeah, It came out with some sanding. I don't know how it happened but it's gone now! I'll be even more careful with the next rosette glue-up .Thanks fer asking Larry.[/QUOTE] Hey thank you for the follow up |
