It is currently Wed Aug 20, 2025 4:34 pm
PostPosted: Sat Feb 10, 2007 3:30 am
First name: Jim Howell
Great tutorial! This was a place that I had trouble getting a clean joint on my 0-16. Thanks for taking the time to put this together.
Jim Howell
Charlotte, NC
PostPosted: Sat Feb 10, 2007 4:10 am
Great post, Hesh! Thanks for taking the time.
PostPosted: Sat Feb 10, 2007 4:21 am
First name: Larry
Last Name: Hawes
WOW Hesh that is a very kind and timely post. I know the effort it takes to put together such well thought out pics and really appreciate the effort. I'm heading the garage to try it.
Larry
Thank You and Best To All
PostPosted: Sat Feb 10, 2007 5:36 am
First name: Larry
Last Name: Hawes
[QUOTE=Hesh1956] I forgot to add, and very important too - make sure your neck angle is correct PRIOR to using the above procedure
Thanks![/QUOTE]
OK I'll bite. How do you insure your neck angle is correct without the fret board at least clamped to it? I'm trying to use a combination of changing the neck angle and sanding that area but it seems I can't get a true picture of the neck angle without that sanding being done, and yet the neck angle should be determined before the sanding is done?
Sorry for perhaps beating this dead horse but I rushed my last neck thinking I would fix it with the set-up and that guitar is so hard to play it doesn't come out very often.
PostPosted: Sat Feb 10, 2007 6:27 am
Hesh, excellent description and illustration - much appreciated.
Question...wouldn't it be better to use a board that is dead flat as I've found that slotted fretboards are not always so?
PostPosted: Sat Feb 10, 2007 6:45 am
First name: Larry
Last Name: Hawes
Thanks again and I do see the situation a little clearer now though Mr. Red is under a coat of Z-Poxy as I write this.
[quote]In the end you want the plane of the fretted neck to about 3-4/16th above the saddle height.[/quote]
Is that a typo? Did you mean bridge height? And doesn't the StewMac instructions ask you to have the plane right ON the bridge height? Isn't 4/16ths a quarter inch? Above the saddle height? That's a bit confusing but I am getting a clear picture of how to proceed from here even though I was very close an hour ago.
I'll wait for the Z-Poxy and try to adjust a little more.
PostPosted: Sat Feb 10, 2007 8:41 am
Great Post Hesh,
All very helpful stuff my friend thank you.
PostPosted: Sat Feb 10, 2007 9:05 am
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Nice work !!!!!
Mike Collins
Mike Collins
PostPosted: Sat Feb 10, 2007 9:38 am
Hesh....
You are totally and utterly ace!!!
I loved your last tutorial of sanding the fretboard face of the neck totally flat.
PostPosted: Sat Feb 10, 2007 1:03 pm
Hesh, you rock man!
Another problem solved!
PostPosted: Sat Feb 10, 2007 1:42 pm
Yeah,You do rock Hesh! Thanks a lot for the great tutorial and explanation.
PostPosted: Sun Feb 11, 2007 5:26 am
Ingeniously simple. Way to go Hesh!
Matt Jacobs
"Don't tase me bro"
PostPosted: Sun Feb 11, 2007 8:20 am
First name: Larry
Last Name: Hawes
Tried all your tips today Hesh and I THINK I have the fretboard angle figured out. Thanks again for all your help it is very generous and much appreciated.
Larry
PostPosted: Sun Feb 11, 2007 12:22 pm
Excellent microtorial Buddy! Keep'em coming!
PostPosted: Sun Feb 11, 2007 12:51 pm
Hesh,
Great post! Thanks!
That's going to be one fine instrument.
PostPosted: Mon Feb 12, 2007 4:48 am
great tutorial bro, thanks!
